Aftermarket MT shift knobs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by offthewallsurfer, Jan 23, 2017.
  1. Mar 1, 2021 at 7:08 PM
    #501
    Toyotafanforlife1991
    Toyotafanforlife1991 Live FREE and drive a TOYOTA!!!
    Brandon
    Dickson, Tennessee
    2016 QS Tacoma DCSB OR M/T, 1970 Toyota Land Cruiser FJ40 351W M/T, 1982 Toyota Hilux SR5 M/T, 1983 Toyota Hilux SR5 M/T (undergoing frame off restoration)
    As soon as I have the time and I can get adaptors amd dual cases from marlin with ease my 16 with have a fj manual tcase swap. Half the battle is already won because we know it bolts up perfectly and functions, the hardest part is the second half, get it all to work like factory with no dash lights on or codes thrown. And I say that's the hardest part by far!
    I will not settle for this crappy actuator, I just want a real lever for my tcase. Lol.
  2. Sep 13, 2021 at 1:09 PM
    #502
    Nuova
    Nuova Well-Known Member
    Ashley
    Petawawa, Ontario
    2021 6MT Sport
    OTT7 Tune, 3" lift and a cracked windshield
    Just came here to post these as I really like them..
    - Weighted sphere shift knob in candy red (matches barcelona red great) from Billetworkz
    - Collar from etsy shop Trailbreaker Customs
    - Shift boot from Redline Goods
    All were fairly easy install.
  3. Sep 13, 2021 at 5:56 PM
    #503
    scrubtaco
    scrubtaco Member
    2018 inferno TRD OR
    Plastidip, rainguards, sub woofer...more to come
    I threw the oem trail team fj cruiser Shift knob in my taco use an Amazon shift boot adapter
  4. Oct 27, 2021 at 12:59 AM
    #504
    tylerthompson21
    tylerthompson21 Well-Known Member
    Tyler
    2022 Taco TRD-OR
    Custom Hiatus Pop-Up Hard Sided Camper
    This looks perfect. What does it look like from the side?
  5. Jan 15, 2022 at 7:19 AM
    #505
    JackJoachim
    JackJoachim Well-Known Member
    Jack
    North MS/Memphis
    ‘22 Barca Red TRD Off Road 6MT
  6. Jan 15, 2022 at 3:04 PM
    #506
    SilverBulletII
    SilverBulletII Well-Known Member
    New England
    2017 Silver Tacoma SR, MT, 4 cylinders, 4X4
  7. Jan 29, 2022 at 8:07 PM
    #507
    JackJoachim
    Jack
    North MS/Memphis
    Can someone with the TrailBraker Customs collar take a few measurements for me? I’m trying to get a custom shift knob made.
  8. Jan 30, 2022 at 7:32 AM
    #508
    Nuova
    Ashley
    Petawawa, Ontario
    2021 6MT Sport
    What measurements you looking for? like diameter and height and opening? I can but I'm also not gonna take the collar off the shifter.. it's a PITA. Lol
  9. Jan 30, 2022 at 9:17 AM
    #509
    JackJoachim
    Jack
    North MS/Memphis
    Length of threads
    Distance from where the collar sits to the bottom of the threads
    and if possible the size of larger part of the shift lever below the thread. Like how it increases in size as you go down to the collar if that makes sense.
    Thanks in advance.
  10. Jan 31, 2022 at 5:46 AM
    #510
    Nuova
    Ashley
    Petawawa, Ontario
    2021 6MT Sport
    Here's a diagram i made in paint.. lol. the measurements are not 100% since i used a straightedge ruler and didn't take everything apart. Right side is top view of the collar.
    Below I quoted my post with a picture of what it looks like for reference.
    JackJoachim[QUOTED] and Pablo8 like this.
  11. Apr 7, 2022 at 7:29 AM
    #511
    Cilantr0
    Cilantr0 Member
    IG: @cement.jpg
    WA
    21 Tacoma TRD OR
    Graco Convertible Car Seat Graco Infant Car Seat
    Here my blacked out set up
    Junkhead, Nuova and SilverBulletII like this.
  12. Apr 7, 2022 at 7:49 AM
    #512
    JackJoachim
    Jack
    North MS/Memphis
    What knob?
  13. Apr 7, 2022 at 9:08 AM
    #513
    NoVa TRD Sport
    NoVa TRD Sport Well-Known Member
    Alexander
    Northern Virginia
    2021 Army Green TRD Sport
    Leer cap
    The TrailBreaker collar is not threaded. The inside has a bayonet mount that fits over the OEM chrome boot cap.
    The top of the collar (inside) is large enough that it will slide down pretty far on the shifter shaft. That's why it comes with an O-ring to take up part of the space. I substituted my own flat rubber washer for the O-ring, so that the collar would sit higher.
    pinochle and SilverBulletII like this.
  14. Apr 7, 2022 at 10:24 AM
    #514
    Cilantr0
    Cilantr0 Member
    IG: @cement.jpg
    WA
    21 Tacoma TRD OR
    Shift Solutions Co.
  15. Nov 19, 2023 at 11:34 AM
    #515
    Barney556180
    Barney556180 Active Member
    2023 TRD Sport Double Cab 4X4 Manual
  16. Nov 19, 2023 at 12:12 PM
    #516
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
  17. Nov 19, 2023 at 12:14 PM
    #517
    33yrsoftoys
    joel
    mid Michigan
    By the way that's the one I've got too and I really like it.
  18. Nov 19, 2023 at 12:18 PM
    #518
    Barney556180
    Yes, but the two do not match.
    2.4 inches and 5cm are two different sizes.
    Just want a verification on which it is.
  19. Nov 19, 2023 at 12:21 PM
    #519
    33yrsoftoys
    joel
    mid Michigan
    I'll go check mine and let you know for sure.
  20. Nov 19, 2023 at 12:22 PM
    #520
    redneck_adjacent
    redneck_adjacent Well-Known Member
    Bellevue, WA
    1997 Tacoma 2.7L 4x4 W59 MT
    5 PSI supercharger 3" lift Bilstein 5100 shocks Old Man Emu springs General Spring leaf springs with 2" blocks and extended shackles 31" Firestone Destination XT tires LCE header and catback exhaust HPS CAI Tundra S13WE front brakes KC HiLites flood, ditch, fog, and backup lights Eaton Bussmann relay/fuse panel with custom power tray All Pro bumpers, sliders, and skid plates
