Aftermarket Mud Flap Upgrades
Discussion in '2nd Gen. Tacomas (2005-2015)' started by H2Otx, Jul 8, 2010.
  1. Jul 8, 2010 at 2:49 AM
    H2Otx
    H2Otx [OP] The Tinkerer
    Austin
    Houston, Texas
    10 DC 4x2 SR5 TRD Off-Road
    SilverStar Ultra Headlights; Nokya Ion Yellow Fogs; SuperBright LED Bulbs; 8" Shorty Antenna; WeatherTech Mats / Bug Shield / Vent Visors; TRD CAI with aFe Pro Dry S Filter; aFe Pre-Filter; Custom CAI Cover and Fuse Box Cover; TRD AT Shift Knob (Japan); TRD Oil Filler Cap (Japan); n-Fab Step Rails; Monster Hook
    Ok, first let me say: DON'T post if you aren't going to contribute to the topic! I have my reasons of wanting mud flaps and that is that.
    With that said...
    2010 Toyota Tacoma, brand spanking new and want to keep the paint that way. The factory mud flaps look gay and bend at highway speeds.
    I want to replace them and upgrade them with some rubber and slightly wider to protect the sides. I have the TRD Ivan Stewarts and the tires sit outside the fender wells about an inch and sling crap up on the sides.
    Any recommended aftermarket mudflaps? Any that fit without drilling or mods?
    I am going for tasteful NOT over the top or gaughty.
  2. Jul 8, 2010 at 3:54 AM
    KodiakVA
    KodiakVA Well-Known Member
    Richmond Virginia
    09 4x4 XCab Sport BarcelRed
    You might try WeatherTech. People here are trying to get them to make their no drill type for the Tacoma. Perhaps they do now.
  3. Jul 8, 2010 at 4:06 AM
    tegdog
    tegdog Taco Lover
    Indiana
    09 Tacoma Dbl TRD Sport
    ventvisors,seatcovers, bug shield,TRD CAI,TRD CAT BACK,blacked out emblems,bed extender, TSB leaf pack,Pro Dry filter, Grill craft upper, lower, & triangles, Hella 500 Black magics
    Try oriley auto parts, I bought a set of front & rears there for my Taco look good & perform better than the OE. They are sorta custom fit, you cross refrence a chart and it tells you what generic set fits your truck.
  4. Jul 8, 2010 at 5:49 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Check into Powerflow Pro-Fit, but they still may not cover it well enough since your wheels are offset more than stock. You may need to look into Bushwacker flares to get the coverage you need.
    Note that I also have the flinging issue as I have a set of rims that are +25 offset instead of the standard -5. I am running without any flaps and get the dirt/mud/etc. flinging down the sides.
  5. Jul 8, 2010 at 6:11 AM
    headhunter247
    headhunter247 Well-Known Member
    St. Louis, MO area
    13 Taco Double Cab TRD
    Bilstein 5100's all around, front set at 2.5", Toytec AAL, 265/75/16 Duratracs, Pro Comp 5001, Weathertech's, AVS In Channel Visors, Nokya Hyper Yellow fogs, CB Set up, Color matched grill surround, ATC Camper Shell with Yakima Racks, SOS Concepts Regular Rear Bumper.
    I bought a set of generics from autozone that work well, I dont recall the name. I had to do a little trimming on them to make them fit, but for $30 it was well worth it vs. the cost of stock flaps.
  6. Jul 8, 2010 at 6:43 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
  7. Jul 8, 2010 at 11:13 AM
    SplitDecision
    SplitDecision Phones Ringin Dude
    Haywood Jablowme
    NY
    Silver TRD OR
    Bilstein 5100x4, Truxedo lo pro QT,Hid Retro,2011 painted grill,Alpine head unit,Foglight mod,NFAB steps
  8. Jul 8, 2010 at 4:33 PM
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
  9. Aug 8, 2010 at 11:49 AM
    kman24
    kman24 Member
    Omaha, NE
    06 DoubleCab TRD Off-Road
    Hey there, just wanted to share some information on some splash guards that I am trying out on my truck. They are PowerFlow Pro-Fit Splash Guards and available at JC Whitney for about $35/pair.
    http://www.jcwhitney.com/pro-fit-sp...jcwx?filterid=d2193y2006j1&_requestid=4627122
    Two of my stock ones literally broke off in the cold snowy weather and I used these to replace them. These are guaranteed down to -40 degrees so we will see how they fair this coming winter.
    To mount them I used the existing holes in the fender so I didn't have to drill new holes which was a plus. I just inserted drywall mollies into the holes and then used the screws that came with the splash guard kit.
    Also, I had looked into using WeatherTech since I have their floormats already but they don't have them available for this model. I did put a product request in for them and hope that enough others with follow suite to make them a reality.
    KMan
  10. Aug 8, 2010 at 4:46 PM
    ron.p
    ron.p Member
    I did the pro-ft #7's on the front, about two inches shorter than stock and they are decent quality. $29 at Pep Boys or $15-$20 online such as ebay. They have a nice "lip" to cover the corner damage the stock ones do. I used three of the same holes and drilled a fourth. I held it up straight (keep the bottom level) and used a punch to locate and then mark the holes. Used black nylon license bolts to secure and used the stock screw on one hole. Holds tight, so no flapping in the wind. Sold the stock one on ebay (they go for up to $75+ on ebay) so came out ahead.
  11. Aug 12, 2010 at 2:46 PM
    dmigod
    dmigod Member
    Paul
    Stockton CA
    2007 TRD 4X4 Extra Cab Tacoma
    Did you use the Drywall Mollies on the areas that had the Clips before> I am installing my Model 7's this afternoon to replace the ones I pulled off getting to my riding spot? Thanks!
  12. Aug 12, 2010 at 7:35 PM
    ron.p
    ron.p Member
    I used black nylon bolts with washers on both sides and locking nuts. The bolts are the autozone license plate bolts, separate washers and then they had pack of nuts with the rubber inserts so they lock.
  13. Aug 13, 2010 at 6:31 AM
    kman24
    kman24 Member
    Omaha, NE
    When I installed the pro-fits on mine, I used the green drywall mollies in the 3 existing holes that are located along the fender flare and the screws that came with the new flaps. Since my existing flaps were broken, I trimmed off the back part of it that attaches to the inner part of the wheel well to give the new flap a mounting point on the inside. So, when I was finished I ended up using 4 screws per flap.
    KMan
  14. Aug 13, 2010 at 8:06 AM
    dmigod
    dmigod Member
    Paul
    Stockton CA
    Thanks For the infor guys!:rolleyes:
  15. Aug 13, 2010 at 11:31 AM
    ydoow
    ydoow Active Member
    Phoenix Az
    09 PreRunner
    You can do what I did, and cut down the factory mudflaps for free. Mine don't bend at highway speeds any more. Just a thought
  16. Aug 13, 2010 at 2:29 PM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    Done the exact same thing. They work really well when trimmed
