Aftermarket Or OEM?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueTaco9486, Mar 3, 2023.
  1. Mar 3, 2023 at 1:02 PM
    BlueTaco9486
    BlueTaco9486 [OP] Well-Known Member
    Bunk
    2013 Blue Taco
    Factory Off Road Package
    I’ve recently replaced balljoints on my 2nd Gen With Moog. It’s been only three months and they are already worn. A coworker and fellow Yota owner told me you have to use Toyota parts or that will happen. The thing is, Toyota makes you buy the whole control arm! Should I try Moog again as they are under warranty, or spend the dough on control arms through dealer. Thoughts?
  2. Mar 3, 2023 at 1:04 PM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Def go OEM if you can
  3. Mar 3, 2023 at 1:14 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  4. Mar 3, 2023 at 1:16 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Did you grease the Moog ball joints on installation?
    How do the inboard bushings look on your 10 year-old control arms?
  5. Mar 3, 2023 at 1:17 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Many have reported the quality of Moog has gone down in the past few years.
    But 3 months? That seem like a really short lifespan.
    I’ve used Mevotech on 2 different Ram trucks.
    So far they have held up fine.
    Before you do anything, take a look at the over all condition of your suspension.
    Are you lifted? Do you wheel your truck hard and often?
    3 months is short. I can’t see them wearing out that fast.
    If they did, it would almost have to be a manufacturing defect.
    BlueTaco9486[OP] likes this.
  6. Mar 4, 2023 at 1:18 PM
    BlueTaco9486
    Bunk
    2013 Blue Taco
    The Boots were sealed and pre greased. The control arm bushing are in good shape. It’s a florida truck.
  7. Mar 4, 2023 at 1:22 PM
    BlueTaco9486
    Bunk
    2013 Blue Taco
    The lower joint on the passenger side is really the bad one. The driver side still has life. Truck gently pulls to the right so makes sense. I have bilstein 5100 set at 1.75 lift. So it’s not a huge dramatic lift. I hunt in the WMAs here and I ride gravel roads on the weekends. But I wouldn’t think that would burn out the joints like that.
    TnShooter[QUOTED] likes this.
