Aftermarket Radio Install Help (1st gen)
Discussion in 'Audio & Video' started by oofy15354, Jan 3, 2010.
  1. Jan 3, 2010 at 8:05 AM
    oofy15354
    oofy15354 [OP] Proud Tundra *****
    Dave
    Massachusetts
    Herculiner, Access Tonneau, Uniden cb, firestik antennae, Bosch Wipers, JVC Ipod headunit, Boston Acoustic Speakers
    Ive been reading everything on how to install this damn thing but i still have questions. After looking at this:
    http://resources.jvc.com/Resources/00/01/15/GET0582-001A.pdf
    how do I connect the tweeters in the door?
    should i use the leads for the rear speakers (I have a reg. cab)?
    or are these connected with the front speakers so i only use the white and gray wires?
    for all the speaker wires (2 of each color), does it matter which is positive and negative? theres no indication on them so can i just connect it however?
    last, should i connect the black ground to the harness adapter or should i just ground it?
    thanks guys and gals. im new at this but now im determined to get this done
  2. Jan 3, 2010 at 8:09 AM
    oofy15354
    Dave
    Massachusetts
    i take back the second part. on the harness adapter, the positive and negative sides are labeled, but they arent on the radio harness. does it matter?
  3. Jan 3, 2010 at 4:06 PM
    oofy15354
    Dave
    Massachusetts
    going once, going twice, sold! to the next user to help me!
    (bump)
  4. Jan 3, 2010 at 4:11 PM
    Ese Loco
    Ese Loco Taco Man Sam
    Vero Beach, FL / Tampa, FL
    2009 DC TRD Off-Road 4x4 V6 6-speed
    Legal Florida Tint all-around, 1.5" add-a-leaf, bilstein 5100 rear shocks, Light Racing Coilovers, Removed secondary air filter, K&N airfilter, Amsoil 100% synthetic motor oil, Amsoil synthetic severe gear in rear differential, Differential breather mod, Painted rims and logo's black, amsoil oil filter
    Usually lighter is positive (red,white,grey, etc.) and darker or a light colored with a dark stripe is negative (black, white with stripe, etc.).
    The polarity of the wires absolutely does matter in order for your system to even work.
    Tweeters should run to a crossover that also connects the mid as well to the head unit or amp.
    As to the ground, I can imagine you could do either as long as you ground it properly.
    This might help you as well
    http://www.the12volt.com/installbay/forum_posts.asp~TID~34680
  5. Jan 3, 2010 at 4:31 PM
    oofy15354
    Dave
    Massachusetts
    for each speaker there are two of the exact same wire, one for +, one for -.
    for example, there are two gray wires for the right front speaker. on the harness adapter i got, the positive and negative are labeled. on the wire bundle that connects to the back of the head unit, there are no labels so idk which is which.
    for the ground, i figured as much but wanted to be sure.
    now when you say the crossover connects the mid, what is a mid?
    sorry for the n00b questions but electrical is not my thing. thanks for the input
