Aftermarket Receiver Issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ShaneC, Jan 26, 2020.
  1. Jan 26, 2020 at 5:29 PM
    ShaneC
    ShaneC [OP] Member
    Shane
    2008 Toyota Taccoma Off Road
    I purchased an aftermaket head unit a few years back (Pioneer AVH-X2700BS) for my 08 Tacoma with the JBL upgrade. I installed it myself and am more used to wiring a house than wiring car audio. I might use the wrong terminoligy, so bare with me. My problem is the quality of the music coming through the speakers. It seems like the levels aren't coming through correctly and when I turn up the volume to a high level, the clarity tanks and it seems like all power is coming out of the sub. I am not sure if this is an indication that I wired something wrong, my amp is going bad or something else. I am thinking it might be a crappy receiver but this is not my forte. Any recommendations would be appreciated.
  2. Jan 26, 2020 at 5:33 PM
    Bishop84
    Bishop84 Well-Known Member
    I'd open up the harness and check all solders. If you used crimps it may be the issue. It's always my starting point.
    Also check the ground wire.
  3. Jan 26, 2020 at 7:08 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    To clarify;
    Did your truck come with the JBL system from the factory?
  4. Jan 26, 2020 at 7:17 PM
    DG92071
    DG92071 Well-Known Member
    I can guarantee you that your receiver is a quality piece. Pioneer is the only manufacturer to use MOSFET outputs on their receivers.
    I have no experience with the JBL system that's in some Tacomas.
  5. Jan 27, 2020 at 4:28 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Did you have the steering wheel control module along with the wiring harness in order to retain the factory steering wheel controls and amp?
    DG92071 likes this.
  6. Jan 27, 2020 at 7:57 AM
    ShaneC
    ShaneC [OP] Member
    Shane
    Will do. I crimped the wires, but I will go back, recheck connections and solder them. Thanks for the starting off point.
  7. Jan 27, 2020 at 7:59 AM
    ShaneC
    ShaneC [OP] Member
    Shane
    Yes to both. It came with the JBL system and I have the steering wheel control module.
    TnShooter[QUOTED] likes this.
  8. Jan 27, 2020 at 11:41 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    Did you have to mess with the amp and it's connections at all during the install?
    DG92071 likes this.
  9. Jan 27, 2020 at 11:44 AM
    ShaneC
    ShaneC [OP] Member
    Shane
    No I didn't. I only touched the wires behind the receiver and I don't recall any wires referring to the amp in the diagrams. It has been a while since I installed them, but I will verify tonight when I get off work.
  10. Jan 27, 2020 at 4:28 PM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    Is this the harness that you have?
    Axxess TYTO-01 Wiring Interface
    DG92071 likes this.
  11. Jan 27, 2020 at 4:44 PM
    ShaneC
    ShaneC [OP] Member
    Shane
  12. Jan 27, 2020 at 4:58 PM
    ShaneC
    ShaneC [OP] Member
    Shane
    Another thing I forgot to mention is the subwoofer controls on the vehicle do not work. I can jack up the subwoofer all the way, or turn it all the way down and it makes no difference
  13. Jan 27, 2020 at 5:02 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Do you have a set of spare speakers? Just to test if they are blown.
  14. Jan 27, 2020 at 5:04 PM
    ShaneC
    ShaneC [OP] Member
    Shane
    I do not. I thought that but it seemed like it would have to be a big coincidence that it happened right when I got a new receiver. My initial thought is is if the receiver is good, then it's either the speakers or the amp. But there again, I really don't know what I'm talking about
  15. Jan 27, 2020 at 5:07 PM
    rnish
    Tacoma 2nd gen
    So everything was good. Then you replaced “only” the amp. Now it sounds like crap?
  16. Jan 27, 2020 at 5:08 PM
    Kennyluu611
    Kennyluu611 Well-Known Member
    Kenny
    SoCal
    2010 Tacoma DCSB Prerunner 4x4
    King 2.5 JBA HD UCA Dakar Rear Leaf US Off Road Bumper Winch 4x4 Converted TRD Supercharger
    TnShooter and DG92071 like this.
  17. Jan 27, 2020 at 5:08 PM
    ShaneC
    ShaneC [OP] Member
    Shane
    Everything was good and I only replaced the head unit
  18. Jan 27, 2020 at 5:12 PM
    ShaneC
    ShaneC [OP] Member
    Shane
    I didn't think to verify that at time of purchase because I ordered the head unit and all the harnesses etc through crutchfield and that's the one they said was for my truck with jbl. Could that cause all the issues I am having? I thought it was just for the steering wheel controls?
  19. Jan 27, 2020 at 5:13 PM
    DG92071
  20. Jan 27, 2020 at 5:28 PM
    ShaneC
    ShaneC [OP] Member
    Shane
    TnShooter likes this.
