Aftermarket? Replacement Key
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rixhawz, Jan 20, 2022.
  1. Jan 20, 2022 at 3:33 PM
    Rixhawz
    Rixhawz [OP] Member
    Rick
    2019 Graphite Tacoma SR5
    I recently bought a 2109 SR5 used, and love it. But it came with just one key. I’m still shaking my head at sticker shock - dealer wants almost $450 for a replacement key and programming.
    I see blanks for sale on eBay, and I imaging getting it cut is a matter of finding the right lock shop, but the programming? Are there online stores/hacks/apps for DIY?
    thanks
    Rick
  2. Jan 20, 2022 at 5:51 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    lowes / homedepot cut my key i bought off ebay and i used tech stream to program the chip to the truck. pretty easy
    Skydvrr likes this.
  3. Jan 20, 2022 at 6:01 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Which key/key fob do you have? is it an H key stamped on it? Local locksmith might be able to provide a replacement and program it for far cheaper than dealer.
    Also Toms Key, some here have used this service.
    https://tomskey.com/
    2nd gen forum have bought a cheap H key off Amazon or ebay and a cheap programmer not sure if it would work for 3rd gen.
    Rixhawz[QUOTED][OP] and Vikter like this.
  4. Jan 20, 2022 at 6:42 PM
    mushroom_man7
    mushroom_man7 Well-Known Member
    as the other user said Tom's Key is a good solution. I actually just made a spare key a couple days ago with Tom's Key. The only problem was i got rejected by two lock shops to cut the key. they said they dont do work on "internet keys" because sometimes the aftermarket keys stop working and the customers blame the lock shop. I did find a lock shop that would cut it. total cost was just a little over $100. pretty easy. also, maybe make two spares while youre at it. might as well save $40 if you end up losing another key.
    Rixhawz[OP] likes this.
  5. Jan 20, 2022 at 6:42 PM
    Crosbaugh
    Crosbaugh Well-Known Member
    Tomskey programmed my push start key fob for a 2021 OR without issue. It did not work on the Lexus credit card key.
  6. Jan 20, 2022 at 6:47 PM
    mabupa
    mabupa Well-Known Member
    Miguel
    2021 trd off-road 6 speed manual
    I have a 2021 with the “H” stamped on the key and bought a key on eBay and then used tom’s keys service to program it. After that, all I did was go to the local locksmith I’ve used in the past and $5 dollars later I walked out with my new cut key. All in all, I think I spent about $100 total. If you don’t mind spending a little more, you can purchase the key from tom’s key when you rent their tool.
  7. Jan 22, 2022 at 3:09 PM
    Rixhawz
    Rixhawz [OP] Member
    Rick
    Thank you all!
    mabupa likes this.
  8. Jan 22, 2022 at 4:21 PM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    I used toms key as well. Definitely won't be disappointed.
