Aftermarket Rim and Tire question...
Discussion in 'Wheels & Tires' started by JZone, Apr 2, 2009.
  1. Apr 2, 2009 at 8:23 AM
    JZone
    JZone [OP] Member
    i did a few searches here and found that people experienced problems after changing their wheels...
    if i go with a bigger rim but the same size tire as the stock, will i need to modify/fix anything? or is it pretty much a clean swap?
  2. Apr 2, 2009 at 8:30 AM
    gouge44
    gouge44 $DO WORK$
    FloRiDa
    08 prerunner TRDsport DoubleCab
    Tinted windows, toytec ultimate 3inch lift- front c/o rear aal, 18" black rockstar rims, 275/70/18 toyo opencountry mt's, BLUE dome light, 6000k H4 HID bixenon, kenwood kvt-514 headunit,black badges, satoshi grill :] sold it and now have a wrangler....
    should be a clean swap as just depends on the offset
  3. Apr 2, 2009 at 8:33 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    bigger rim? but same size tire?
    not sure i understand :confused::D
  4. Apr 2, 2009 at 8:33 AM
    Brunes
    Brunes abides.
    Rotorhead
    That depends on what you mean by "same size as stock"
    If you mean the overall diameter measure will be the same...you should be fine provided the offset/backspace doesn't impinge on the brakes or any other under car items.
    If you mean you are going to keep the 265/65 or whatever you've got but you are going to make them on a 17 inch rim instead of a 16 or a 18 instead of a 17 or whatever...you are going to add an inch to the tire diameter. Probably not enuf to worry...but you do need to keep it in mind. Minor trimming might need to happen.
  5. Apr 2, 2009 at 8:51 AM
    David Tarantino
    N.J.
    08 tacoma
    JZone did you mean to say that you are keeping
    the same size wheel and want to go up in tire size? :)
  6. Apr 2, 2009 at 10:08 AM
    JZone
    JZone [OP] Member
    yes, diameter the same, but wanting to do an 18 instead of a 16.... im wondering if the tire would look too small...
  7. Apr 2, 2009 at 10:16 AM
    Brunes
    Brunes abides.
    Rotorhead
    Do you have the 245 or 265 tires now?? Is your truck for offroad or street??
  8. Apr 2, 2009 at 10:19 AM
    Brunes
    Brunes abides.
    Rotorhead
    Playing with the numbers I don't think they will look to small...you'll lose some sidewall height which may make the ride a bit stiffer...but they won't be super skinny.
  9. Apr 2, 2009 at 10:41 AM
    JZone
    JZone [OP] Member
    245/75/16 and just for street
  10. Apr 2, 2009 at 10:48 AM
    Brunes
    Brunes abides.
    Rotorhead
    With a 245/65R18 your tire will get about .07 inches larger (aka-it'll fit just fine) and it won't look too small IMHO.
    Good luck!!
  11. Apr 2, 2009 at 11:03 AM
    JZone
    JZone [OP] Member
    If i go with a slightly bigger tire, does that effect the odometer?
  12. Apr 2, 2009 at 11:05 AM
    Brunes
    Brunes abides.
    Rotorhead
    General consensus is the odometer reads correctly but the speedometer may be off by as much as 10%.
  13. Apr 2, 2009 at 11:08 AM
    JZone
    JZone [OP] Member
    hey brunes, i greatly appreciate all the info... i think i may try my luck with a 265-70-18 tire, what you think?
  14. Apr 2, 2009 at 11:16 AM
    Brunes
    Brunes abides.
    Rotorhead
    That's a 32.61 inch tire- You might have a bit rubbing on the fender with that but I'm not sure...I think 33 is about the max without a lift....but I need to look for that answer.
    My sport comes with a 265/65R17...and yours are 2 inches taller than that. I think it could work...but don't take my word on it...I'm still figuring this stuff all out!!
