Aftermarket roof racks and leaks, root causes?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TheSortaHawaiian, Dec 8, 2021.
  1. Dec 8, 2021 at 5:06 PM
    TheSortaHawaiian
    TheSortaHawaiian [OP] Well-Known Member
    21 Lunar Rock TRD Pro
    Hey-o,
    Question. I have an RCI roof rack waiting to be installed and want to plan it out and I've been wondering about the root cause of leaky roofs due to rack installs. I haven't really been able to find a picture/diagram of what I'm looking for. What's actually causing the leak? Are the bolt holes/threads in the stock location not actually sealed? Is it more of just a thread into the interior? What's the actual path the water takes to get in?
  2. Dec 8, 2021 at 5:09 PM
    jsnow77
    jsnow77 Well-Known Member
    Jake
    New Hampshire
    2022 Limited Nightshade
    Take a look at this video starting at 4:02 you can see him take off the weather stripping and install silicon before putting in the bolts for the rack
    https://youtu.be/31DVeJn9HlM?t=242
    AmateurTaco1313 likes this.
  3. Dec 8, 2021 at 5:14 PM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    Use a hersheys kiss amount of silicone on the holes when putting the mounting bolts in. Won’t have any issues
  4. Dec 8, 2021 at 5:15 PM
    TheSortaHawaiian
    That's a good view, a lot of videos I've watched just poke a hole through the tape. So do the holes themselves just lead directly into the cab? I always imagined the holes to be sealed...maybe I have to pull the headliner out to get a better picture of it all...
    I'm mostly just curious as to how the holes are built into the roof. Imm use silicone for sure. Would love to understand more though
  5. Dec 8, 2021 at 5:17 PM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    Im not sure what path the water gets in. But ive installed 3 aftermarket rood racks (2 on tacomas and 1 on my GX470) proper use of silicone or rtv is all it takes. Lay down sealent around the bolt holes before placing the rack down on the roof. Get your bolts started. Lay down more sealent between the bolts and the mounting surface. When you tighten everything down, the sealent will spread.
    Not that bad of a job.
  6. Dec 11, 2021 at 5:34 PM
    Arf05233
    Arf05233 Active Member
    2018 Cement Trd off road
    Vinyl on hood and tailgate
    Is there an advantage when using rtv over just plain old sealant?
  7. Dec 11, 2021 at 5:39 PM
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    I use RTV b/c i can get Permatex brand in the pressurized can.
  8. Dec 11, 2021 at 5:41 PM
    Arf05233
    I am asking because I am going to install a roof rack myself soon and I have a tube of Henry's sealant unused at home. Should I go out and buy rtv silicone or will my sealant be fine?
  9. Dec 11, 2021 at 6:28 PM
    stay_tuned
    stay_tuned Limitations live only in our minds
    Bryan
    DMV
    2021 Tacoma OffRoad DCSB 6SPD BRM
    is there a reason no one uses butyl tape instead of silicon? i’ve never been a fan of globs of silicon that always end up all over the place.
    in the past i’ve just put butyl tape around the washer/spacer and never had an issue and saves the threads from being covered in glop and never had a water leak
