Aftermarket rotors? The OEM's suck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by peppinoss, Oct 17, 2017.
  1. Oct 18, 2017 at 2:03 PM
    #41
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Cross drilled/dimpled are for cooling. Slotted is to help channel brake dust away from the rotor so that it won't build up
    lynyrd3 likes this.
  2. Oct 18, 2017 at 2:40 PM
    #42
    ackshen
    ackshen Well-Known Member
    Golden, CO
    2016 Black TRD Sport DCSB 6MT
    Magnuson Supercharged, 6112/5160
    It's not hard at all. Find a good YouTube video from someone who knows what they're doing, probably could easily find one on this site. I can't imagine the brake assembly changed much, if at all, from the 2nd gen. Rotors are incredibly easy.
  3. Oct 18, 2017 at 2:58 PM
    #43
    Jaque8
    Jaque8 Well-Known Member
    2017 Inferno TRD OR
    drilled rotors are fucking stupid, total marketing gimmick at this point.
    All they do is make your brakes WEAKER (more prone to cracking) and they reduce the surface area of the rotor thereby also reducing performance.
    10 years ago brake pad material wasn't as advanced as it is today so you could get more fade resistance by using drilled rotors, although the weaknesses listed above still applied. Today brake pad material is much more advanced and you don't even get the advantage of fade resistance until you get into the super highend carbon ceramic brakes... even then most of them don't use drilled, only slotted.
    Go look at any GT racecar... none of them use drilled rotors.
    Drilled rotors are only for LOOKS.
  4. Oct 18, 2017 at 3:04 PM
    #44
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    more to vent gas than dust IIRC.
    pjensen641 likes this.
  5. Oct 18, 2017 at 3:07 PM
    #45
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    Yes and no. Cheap rotors that are drilled are weaker. Rotors that are CAST with ventilation are not weaker. This is why high end cars still use the "drilled" rotors.
    See Porsche 918
    MB E63S AMG
    BMW M4 GTS
    I ran aftermarket cross drilled and slotted rotors on my c55 amg that weighed 3600 pounds and had no issues with the rotors after a half day track events that were 15 minute heats each.
  6. Oct 18, 2017 at 3:26 PM
    #46
    Jaque8
    2017 Inferno TRD OR
    Kind of... you're correct CAST rotors are stronger, but no one actually buys cast rotors, its always drilled which is what we're talking about here so the cast thing is kind of irrelevant but a good point nonetheless.
    HOWEVER, its well known in the BMW community (which I've been a part of even longer than the Toyota world and actually sold BMWs at the largest ///M dealer in the California) that the "drilled" rotors are only around because of marketing, people expect to see holes in the high performance rotors so BMW still puts them on.... but go look at the BMW M3 GT racecar, won't see holes because their actual race car is 100% about performance not image, so they ditch the holes, same with all formula/indy/LeMans racecars, none of them use drilled or even cast rotors anymore because it doesn't provide any real racing advantage, only introduces weakness.
    Again its all because of modern brakepads that don't offgas like they used to, which is a pretty recent development. So its gonna take a while before people stop associating drilled rotors with performance.
    Drilled or even cast rotors are just not necessary with modern brake pad compositions, they look cool but that's it... useless on street applications, even worse on a truck.
    James_Bond likes this.
  7. Oct 18, 2017 at 3:35 PM
    #47
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    Interesting, because you still the drilling on high end cars like the ferrari FXXK, porsche 918, Ford GT but on the Ford GT race car itself, they have slotted but not drilled.
    I guess they give what consumers want.
  8. Oct 18, 2017 at 3:40 PM
    #48
    CR2014Sport
    CR2014Sport Well-Known Member
    Craig
    SoCal
    2014 Sport
    Stuff... Need more stuff
    This did in my brakes as well... I was towing my trailer down the hill...
  9. Oct 18, 2017 at 3:51 PM
    #49
    johnny6
    johnny6 Unknown Member
    Northern California
    '17 DCLB 4X4
    modern brake pads don't gas off like old ones used to anyways, but yeah thats the main function of the holes... as the pads heat up they discharge vapor (which boils in the heat) resulting in brake fade under heavy use. i did some research when choosing my last batch of pads/rotors for my yamaha.
    which brings me to my next point, want better brake performance? the pads matter! get good ones
    rlx02[QUOTED] likes this.
  10. Oct 18, 2017 at 4:04 PM
    #50
    OffCamber00
    OffCamber00 Well-Known Member
    mat
    Charlotte
    2017 Super White SR5 DCSB
    So much misinformation in this thread.
    96ti and cliffyk like this.
  11. Oct 18, 2017 at 4:07 PM
    #51
    Jaque8
    2017 Inferno TRD OR
    yup, marketing. An extreme example of this is the fact that the Porsche 911 is still a rear engine car. Porsche knew by the late 70s that it was an inferior design, but by then it was already ICONIC. So to keep the classic image of the 911 they've been doing some engineering magic to make up for the rear engine, it was only until the recent 991 Carrera that they finally got rid of the snap oversteer. To remain competitive in racing they finally made a mid-engine 911 this year (the RSR) because at that level of competition they simply couldn't stick with the classic design just for the sake of being classic anymore.
  12. Oct 18, 2017 at 4:10 PM
    #52
    johnny6
    Northern California
    '17 DCLB 4X4
  13. Oct 18, 2017 at 4:16 PM
    #53
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    *ceramic
    newbson9696[QUOTED] likes this.
  14. Oct 18, 2017 at 4:29 PM
    #54
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
  15. Oct 18, 2017 at 4:34 PM
    #55
    OffCamber00
    mat
    Charlotte
    For the record, all 911s were and continue to be delivered from the factory setup to understeer. They only oversteer when you ask them to.
    Also, the new RSR is mid engine not because a mid engine platform is better. Its mid engine because for 2017 the ACO opened up the rule book to allow more aggressive use of rear aero. Hard to do when you have an engine where you want your tunnels to be.
  16. Oct 18, 2017 at 4:48 PM
    #56
    OffCamber00
    mat
    Charlotte
    I believe what he is saying is that rotors with the holes cast into them are much stronger than cast rotors that are later cross-drilled. In the former, the holes are part of the mold and the structure of the rotor is not disrupted by later drilling. This is why high end rotors that are "cross drilled" use this method of manufacture vs actual cross drilling.
    None of this to be confused with venting which is what is shown on the F1 car above.
    James_Bond and johnny6 like this.
  17. Oct 18, 2017 at 4:57 PM
    #57
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Most brake shutter isn’t caused by rotor warpage. It’s caused by pad desposits. The way to prevent that is good pads, and make sure you don’t heat up the brakes and then park the truck immediately.
  18. Oct 18, 2017 at 5:04 PM
    #58
    OffCamber00
    mat
    Charlotte
    I have only seen this in racing applications where the pad is designed to leave deposits that create a higher friction surface for the pad material to bite into.
    In my experience, most street car shudder instances are caused by rotor run out. This can be caused by many things but is typically due to cheap ass rotors warping from heat as they wear thinner.
  19. Oct 18, 2017 at 5:07 PM
    #59
    smmarine
    Melbourne FL
    All pads are designed to leave deposits on the rotor. That’s what helps get the best bite. But when you heat up the pad and rotor and the vehicle rests too long in one spot, it will transfer too much pad material, and cause deposits.
    OffCamber00[QUOTED] likes this.
  20. Oct 18, 2017 at 6:05 PM
    #60
    MikeM
    MikeM Well-Known Member
    Florence, KY
    17 TRD Sport 4x2 DCSB Blazing Blue Pearl
    Bright stuff
    interesting comment , every Porsche I've owned in past 20 years has had Drilled rotors stock, Granted the Calipers are Brembo's but I can track/AutoX my 911 with no fade, no warping, for 30K miles on set of pads and rotors. Drilled /Slotted doesn't matter?, what matters is size and how they are cooled.
    The primary reason for drilled rotors is to get rid of the gas buildup between the pad and rotor, same with the slots. Are far as cool, yeah it's cool to be able to brake the car repeatedly without fade and out brake the guy next to you diving into the corner at Mid Ohio or other real track,
    Not Expensive, One 911 rotor costs more than both Taco rotors even from aftermarket suppliers. As far as Drag Racing, You only have to maximum Brake one time before the Pads and Rotors cool off, Fuel (Nitro) cars TF/FC don't even have Front brakes.
    The guy with the StopTech's knows what stopping power is. Also you Guys that rely on Downshifting , one thing to keep in mind, Brakes are cheaper than Transmissions and motors. Not that I don't do it ever, but I limit my usage of brake compression.
    Face it , The Taco and most other Automobiles don't have enough brake capacity, Just ask any owner of a Chevy Silverado or Suburban that tows.
