Aftermarket speakers for Tacoma
Discussion in 'Audio & Video' started by stanbp64, Aug 19, 2012.
  1. Aug 19, 2012 at 2:34 PM
    stanbp64
    stanbp64 [OP] Well-Known Member
    Greenville, SC
    2011PreRunner Sr5
    Any body installed these: Polk Audio DXi690 in their front Tacoma DbC doors? ********* said thier brackets/spacers would work with any 6x9 with mounting depth of 3 1/4". These are 3 3/16. Pretty close for comfort. also looking at the Boston Acoustics SC95 which would def. fit. Any opinions on these two speakers? I have a Pioneer AVH-P2400BT HU. No amp. Also, if I use three way speaks up front, should i still connect the tweeters that are in there already? Thanks for any advice,
    Stan
  2. Aug 19, 2012 at 2:41 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    3-3/16" is less than 3-1/4" so they will fit.
    If you're concerned, get some 1/4" weatherstripping and stick it around the opening on the adapter to move the cone out so it'll only be 3-1/16" after the weatherstripping compresses.
    I'm running a Polk DB6501 component system and it fits perfectly (but it's only 2-5/16" deep). Keep in mind that the TT adapters will give you about 3/4" more than factory.
    I mounted my crossover under the armrest.
  3. Aug 19, 2012 at 5:25 PM
    stanbp64
    Greenville, SC
    2011PreRunner Sr5
    Yeah i know 3 3/16 is a 1/16 less than 3 1/4 just thought it might be too close for comfort...who knows what kind of tolerances these guys hold. Just ordered the adapters, just have to decide on some 6x9's. Any opinions?
    Stan
  4. Aug 20, 2012 at 3:25 PM
    TheWeatherman
    TheWeatherman Well-Known Member
    Brian
    Fort Collins, CO
    2010 SR5
    Color matched (Grill, Handles, Bed Handle, Side-View Mirror Housing), Sport Shocks, BHLM, Black Painted Steel Wheels 16"
    I was planning on using those same speakers. I would love to hear about what you pick.
    I would also like to hear about if you need to reconnect the tweeters because the DXi690 have them in the speaker. I thought about replacing the 6x9 with the DXi690 and then some polk tweeters as well, but I am unsure if it would mess anything up.
  5. Aug 20, 2012 at 4:40 PM
    stanbp64
    Greenville, SC
    2011PreRunner Sr5
    Yes, that is part of my dilema. I know everyone has an opinion on speaks but was hoping someone had some experience with either of these.
