Aftermarket Switch function?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ccrames2018, Jul 18, 2025.
  1. Jul 18, 2025 at 10:28 AM
    Ccrames2018
    Ccrames2018 [OP] Jack of some trades.
    Caden
    Nor Cal
    06 DCLB TRD Sport
    -Bilstein+OME suspension, ARB bumper w/Smittybuilt XRC winch, Aero exhaust, CMC, oddball size 275/70R17 General Grabber ATXs on 17x8 0 offset Pro Comp wheels, etc.
    I just bought an 06 TRD Sport from a coworker and there is a rocker switch on the dash with 3 wires going into it. When turned on it lights up the ABS light and the differential lock light, even though there is no diff lock on the truck. Any ideas as to what this does aside from deactivating ABS? Does anyone know if there is a specific thread for that mod? I’ve seen a few threads about the yellow wire mod and an ABS kill switch one, but nothing that causes the diff lock light to turn on in a TRD Sport model. My coworker said it turns off the LSD, but with it on and off, in 2wd and 4wd, both rear wheels still spin at the same time in dirt. I’m not too sure what else it would do.
  2. Jul 18, 2025 at 10:44 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds like it's a switch to disable the ABS.
    lowmower likes this.
  3. Jul 18, 2025 at 11:09 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    WAG. Search on "yellow wire mod".
  4. Jul 18, 2025 at 11:48 AM
    Ccrames2018
    Caden
    Nor Cal
    06 DCLB TRD Sport
    Yeah I know it disables the ABS and I’ve read the YWM threads, just want to know why it lights up the light for a diff lock when this truck doesn’t have one
  5. Jul 18, 2025 at 12:02 PM
    hinmo24t
    hinmo24t MAhole
    tom
    dartmouth, ma
    2015 TRD OR , blue ribbon metallic
    you sure it doesnt? would be sweet if it did
    good luck too
  6. Jul 18, 2025 at 12:06 PM
    Ccrames2018
    Caden
    Nor Cal
    06 DCLB TRD Sport
    I’m definitely no expert with differentials and aftermarket wiring, but I’m assuming if it had a locker in it there would be an actuator and some wires attached to the rear diff aside from just the ABS sensor wires right?
  7. Jul 18, 2025 at 12:07 PM
    rnish
    Tacoma 2nd gen
    Blue Tooth locker.
  8. Jul 18, 2025 at 12:54 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Most likely because of how they have it wired, even if the truck doesn't have a diff lock the indicator light is still there.
    I can draw and post the diagram later to explain.
  9. Jul 18, 2025 at 1:39 PM
    Ccrames2018
    Caden
    Nor Cal
    06 DCLB TRD Sport
    That would be awesome!
  10. Jul 18, 2025 at 6:38 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Factory E-Locker looks like this, it's only available on TRD OffRoad and TRD Pro (2015+) models.
    Unless someone did an axle swap/added a locker your TRD Sport doesn't have one.
  11. Jul 18, 2025 at 7:34 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I sketched this up, this is how the Diff Lock Indicator is wired. We have Connector DB Pins 7 & 14 and DD Pins 4 & 12 connected together through J/B No 1.
    Assuming this is not a TRD OffRoad DB Pin 14 goes to the Combination Meter (Instrument Cluster) Diff Lock Indicator Light, DD Pin 4 goes to Ignition Power from the IG1 No 2 Fuse, DD Pin 12 goes to the Skid Control ECU (ABS Module) thus keeping that wire at battery voltage.
    Now if we cut the wire here and put a SPDT switch in like this when we turn the switch on DD pin 4 would be grounded, this signals to the ABS that the diff is locked (which disables ABS and turns on the ABS light) and also turns on the diff lock light.
    Now if we were to instead cut the wire and install the switch here we would still signal to the ABS module the diff is locked but we wouldn't turn on the diff lock light.
    Ccrames2018[OP] likes this.
  12. Jul 18, 2025 at 11:13 PM
    Ccrames2018
    Caden
    Nor Cal
    06 DCLB TRD Sport
    Thank you, that was very helpful in understanding this setup. I think he just wired it the way that it turns the diff lock light on. The only apparent function I have found is disabling the ABS. Again, I appreciate the help!
