Aftermarket tires leading to vibration?
Discussion in '1st Gen. Tacomas (1995-2004)' started by pidro_el_pirata, Sep 22, 2011.
  1. Sep 22, 2011 at 12:42 PM
    pidro_el_pirata
    pidro_el_pirata [OP] Well-Known Member
    Hey all, I've been trying to figure out where my highway vibration is coming from in my truck. The guy at the tire store said my aftermarket tires are part of it, that "Toyotas dont like aftermarket tires," and I'd have to get stock rims and tires again. Naturally I dont want to believe it, so I'm getting my brakes inspected and tires aligned as we speak. But, has anyone heard of this? Is there any truth to this idea?
  2. Sep 22, 2011 at 2:48 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    It's probably tire balance... I mounted and balanced my tires myself. I had to re-balance them 3 times (for a total of 4 times) before they were right. The machines are really finicky and I'm sure the techs just say oh screw it that's good enough and throw them on the truck. Just keep bringing it back and making them re-balance... They'll eventually get sick of seeing you and do it one last time and doing it right.
  3. Sep 22, 2011 at 2:49 PM
    oneBIGroom
    oneBIGroom SSS
    SSS
    SSS
    SSS
    SSS
    Guy that said that must have a Ferd.
  4. Sep 22, 2011 at 2:51 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    I just changed tires last weekend and it is smooth on the highway. I would look at having them rebalanced, also have them checked to make sure they are not out of round for some reason or that a wheel is not causing the issue. Good luck!
  5. Sep 23, 2011 at 3:13 PM
    skeezix
    skeezix The Voice of Experience (mostly negative)
    Colorado
    1998 Limited
    When I bought my 1998 Tacoma TRD new, it came with a no-additional-cost vibration at about 40 mph. I had tried two other trucks of the same model, one had the same vibration and the other did not. Unfortunately the one that did not have the vibration had 265-15 tires (not TRD equipment).
    Before I accepted delivery I had the dealer rebalance the wheels. No help. Then I accepted delivery and took it to two tire shops, one franchise and one independently owned, and had them check the balance. The result was three different weight locations and the vibration was still there at about 40 mph. Steering wheel shimmy.
    I lived with that until 30,000 miles. Then I couldn't stand it any longer so I replaced the stock tires with Bridgestone Revo tires. The vibration was gone. 40,000 miles later I replaced the Revos with Revo II tires. Still no vibration. = happy camper!
  6. Sep 23, 2011 at 3:14 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    X2
  7. Sep 23, 2011 at 3:24 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    dumbass statement by that guy------
    this is correct--------
  8. Sep 23, 2011 at 4:03 PM
    krimson
    krimson Nothin
    TRD Off Road
    :spy:
  9. Sep 23, 2011 at 4:27 PM
    eviele
    eviele Well-Known Member
    Which do you like better?
    I have Revo II's now, thinking about getting the Revo's next.
    Do you notice any difference?
    :threadjacked:
    sorry...
  10. Sep 23, 2011 at 4:55 PM
    millerm20
    millerm20 Member
    mark miller
    charlotte NC
    08 sr5
    make shure the rims are centered correctly.some a/m rims are not machined tight enough and do not center properly
  11. Oct 4, 2011 at 10:58 PM
    skeezix
    Colorado
    1998 Limited
    I was under the impression that Revos are no longer manufactured and were replaced by Revo II. But what do I know...
    Can't say I noticed any difference at all. Both were (are) good sets and I can't find anything negative about either set. Smooth as glass on paved surfaces and no problems off-road.
  12. Oct 5, 2011 at 1:35 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); mattgecko's Underhood Lighting; ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BlendMounted BEL Vector 995; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    x3!
    The OEM tires on these trucks were junk. Everybody I know runs "aftermarket" tires, and I don't know anyone with vibration problems that can't be solved with proper mounting/balancing.
  13. Oct 6, 2011 at 4:44 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    another thing that can cause vibrations in the cardan joint on the driveshaft. on 4x4 models it has a grease fitting that needs to be greased i know from experience
