Aftermarket TPMS Sensors
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gotime242, Oct 8, 2019.
  1. Oct 8, 2019 at 1:49 PM
    gotime242
    gotime242 [OP] Active Member
    Has anyone had any luck with aftermarket TPMS sensors? Or a good source for oem one?
    Im buying new wheels and tires and thinking it would be ideal to be able to just sell my OR wheels as a set ready to go with tires and tpms mounted.
    Tirerack seems like it could be a fairly reliable / good option?
    Thanks
  2. Oct 8, 2019 at 3:06 PM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    I bought a set from Tire Rack and they are identical to the ones from a dealer.
    If you get new sensors, you will need to have the new sensor I.D. numbers programmed into the truck's computer. If you reuse your old sensors, you'll avoid that step.
    Big tall dave and gotime242[OP] like this.
  3. Oct 8, 2019 at 3:12 PM
    surfandturf
    surfandturf Well-Known Member
    CT
    2014 TRD DCLB
  4. Oct 9, 2019 at 3:25 PM
    gotime242
    Great thanks!
  5. Oct 9, 2019 at 3:48 PM
    phadcock
    phadcock Member
    I've got the Schrader ez-sensor 33500 from Kal-Tire. Worked great all summer. You can get the shop to clone the IDs so summer/winter sets will both work. I do wish Toyota would add room for 2 sets of tires in the ECU.
  6. Oct 9, 2019 at 3:57 PM
    Steve0ct
    Steve0ct Well-Known Member
    CT
    2017 TRD Off-Road DCSB White
    I’ve had good luck with VDO brand. Not in a Tacoma, but it’s a good brand.
    They relearned using the other cars relearn procedure. I’m sure Tacoma’s have a relearn procedure too.
  7. Nov 12, 2019 at 8:37 AM
    gotime242
    Ended up going with Tirerack ones, they are working great so far! Thanks all for the help.
    Yann likes this.
  8. Nov 12, 2019 at 8:45 AM
    Tibetan Nomad
    Tibetan Nomad Well-Known Member
    2016TRDOR:DCLB:JBL
    NitroGear5.29,B6112,.25"spcr,SPC:UCA,Diff-drop,ECGS
    B5160,Dakar-HD-leaf-pk+OL,UBolt-Flip,33s,Superbumps
    I bought a single for 5th spare from Discount Tire about 5 months ago. Put it in rotation and it’s been fine so far.
  9. Nov 14, 2019 at 10:43 PM
    redfishh20
    redfishh20 Member
    Oregon Coast
    2017 TRD Sport
    I recently got a new set of wheels and tires from Tire Rack with 4 new tpms, when I took my truck to les schwab after installing my lift they told me that they would have to dismount all tires to get the sensors to read. Is this complete bullshit? I was under the impression that there was a tool that could scan the sensors and get the truck to read them..Ill be taking it to tire rack to try soon but its over an hour away. Anybody have any input on this?
  10. Nov 15, 2019 at 4:55 AM
    RichVT
    Rich
    Northern Vermont
    There is a tool that will read the sensor ID's. It's a hand held tool that you point at the valve stem - no need to dismount.
    Once you have the ID numbers of the new sensors, they need to be programmed into the truck's ECU using a tool that plugs into the OBD2 port under your dash.
    redfishh20 and Yann like this.
  11. Nov 15, 2019 at 9:25 AM
    redfishh20
    redfishh20 Member
    Oregon Coast
    2017 TRD Sport
    Thanks man
