Aftermarket TPMS
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rwilche1, May 23, 2017.
  1. May 23, 2017 at 8:19 AM
    rwilche1
    rwilche1 [OP] Active Member
    Russ
    GA
    16' TRD OR 4X4 DCSB
    Hey all,
    Try and make it short and sweet. Ordered my Tire and Wheels from SD wheel online. Long story short wrong tpms sensors were installed. They've made it right and sent me back the correct ones (Huf brand) according to Huf website I made sure they sent the UVS3031. Had Walmart swap out sensors. Those Jabroni's couldn't program. Said they'd "automatically pick up" after certain miles/minutes. Well no dice yet and according to huf site that is incorrect and they have to be programmed (imagine that). I know the issues most have had with the tpms and aftermarket Wheels/tires. I have read many posts about these issues and I called my local Toyota stealership and they quoted me $700! For Toyota tpms to swap em out. I think that's robbery from everything I've seen/researched. I just didn't know if anyone here with turd gens had experience with these huf uvs3031 sensors?
  2. May 23, 2017 at 9:10 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    That price is crazy. OEM sensors can be found for less than 70-80 bucks apiece or better. Mine have never worked since the first rotation. The yelloow light is out so I can live with it.
    G.
  3. May 23, 2017 at 9:11 AM
    Aw9d
    Aw9d That one guy
    Got to discount tire. They'll swap them for around $50/$60 (each). Had to replace a few on my wife's 07 4 Runner and they worked perfectly.
  4. May 23, 2017 at 9:12 AM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    My new wheels and tires roll just fine without them silly sensors.
    over60 and Garyji like this.
  5. May 23, 2017 at 9:15 AM
    Aw9d
    Aw9d That one guy
    That's the way I look at it. As soon as mine stop working I'll remove the LED light out of the gauge cluster and be done with it.
  6. May 23, 2017 at 10:07 AM
    rwilche1
    Russ
    GA
    16' TRD OR 4X4 DCSB
    I'm hoping I can get somewhere to program these huf sensors now. If not I'm gonna ride a while without worrying about it.
  7. May 23, 2017 at 4:01 PM
    rwilche1
    Russ
    GA
    16' TRD OR 4X4 DCSB
    In an update to this. Went by loca tire shop today with an ATEQ tool and had no success. Then got on the horn with SD wheel where they may or may not can send me oem sensors (I'm doubtful).
  8. May 23, 2017 at 4:17 PM
    rwilche1
    Russ
    GA
    16' TRD OR 4X4 DCSB
    If anyone could confirm the correct oem tpms for alloy wheels would work for my application (have alloy- moto metal) is 42607-06030 ?
  9. May 23, 2017 at 4:31 PM
    Jarhead7011
    Jarhead7011 Active Member
    2017 SR5 AC
    Wondering almost the same. Thinking about buying wheels and tire pkg from Discount tires. They offer TPMS sensors for $248. My current setup is SR5 alloys. Do I need to add the Sensors from Discount(or any other online retailer) or can my current ones be switched over? Anyone had recent experience with this?
  10. May 23, 2017 at 6:05 PM
    Garyji
    Gary
    Jarhead, alloy to alloy should work fine. I went from steel to alloy and had to "rig" them to work. Worked until the first rotation, then no corner readouts.
    G.
  11. May 23, 2017 at 7:50 PM
    Jarhead7011
    2017 SR5 AC
    Thanks Gary!
  12. May 24, 2017 at 11:14 AM
    rwilche1
    Russ
    GA
    16' TRD OR 4X4 DCSB
    Can anyone confirm this as correct for me. Company sent wrong tpms sensors after I told them the correct part #. Unreal. Just want to go oem and end my misery. I have found a used set and refurbished ones on eBay.
