Aftermarket tpms's
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ncoutu, Jun 4, 2017.
  1. Jun 4, 2017 at 2:45 PM
    ncoutu
    ncoutu [OP] Well-Known Member
    nic
    2017 Silver TRD Off Road Access Cab
    Icon stage 3 with tubular lift kit. American racing 17x8 inch wheels. BFG 275/70r17 tires. MBRP S5338P 3" Cat Back, Single Side Exit exhaust. Custom trdecals.com trd decals. Debadged.
    has anyone had any luck syncing aftermarket tpms's to their 3rd gen tacomas??? Looking to buy a new set of wheels from tirerack.com and they come with new sensors but want to make sure they will be programmable to my truck before I spend so much money on them!
  2. Jun 4, 2017 at 2:50 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    I have programmable Schrader EZ-Sensors on my 2nd gen, should connect to your 3rd gen no problem if you can find a tire shop that supports them. Discount tire does, when I got mine installed in Louisiana I had to email Schrader to find a local installer as very few had the equipment.
  3. Jun 4, 2017 at 2:55 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Just saying giving info based off a previous Gen might not be that helpful.
    Mainly saying so because although some have got aftermarket sensors to work, many have had issues. Multiple tire shops around here won't even try them. Most of the time only the oem ones are working.
    Garyji likes this.
  4. Jun 5, 2017 at 4:37 AM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    The sensors that I bought from Tire Rack were identical to the factory sensors so I wouldn't call them aftermarket. They were the same brand and part number as the sensors from Toyota.
    These are the ones that I bought:
    https://www.tirerack.com/tpms/detai...coma+4WD&autoYear=2016&autoModClar=Access+Cab
    GPsevinSixx likes this.
  5. Jun 5, 2017 at 9:35 AM
    ncoutu
    nic
    Wow that's fantastic to hear. Thanks so much. I am ordering wheels and tire package with the tpms's but it doesn't tell me what model number they are.
  6. Jun 6, 2017 at 9:47 AM
    ncoutu
    nic
    Another question. Did you have to have the dealership set them up to read on the car's computer?
  7. Jun 6, 2017 at 9:50 AM
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    I called Schrader and was told the 2016 and up (3rd gen) have a different sensor .
    Joe23[QUOTED] likes this.
  8. Jun 6, 2017 at 10:11 AM
    ncoutu
    nic
    So I got in touch with Tirerack and they said they shipped the same tpms's that Toyota uses. So just need to find a way to connect them to the computer. Would something like this work? Anybody have any experience with this? https://www.amazon.com/ATEQ-QuickSe...tDescription_secondary_view_div_1496611385958
  9. Jun 6, 2017 at 11:21 AM
    RichVT
    Rich
    Northern Vermont
    The Ateq quickset tool is what I bought to program the new sensor i.d.'s into the trucks ECU. I use it twice a year when I switch between summer and winter wheels. You need to connect it to a computer (to input the i.d.'s) and then plug it into the OBD II port on the truck. I bought it from Tire Rack as they had the best price at the time.
    You need the i.d. numbers of your new sensors and which wheel goes with which sensor. I don't know if Tire Rack supplies that information. As far as I know, new sensors also need to be activated (woken up, initialized). There is a separate tool that you point at the valve stem and it activates the sensor, reads the i.d. and tells you if the battery in the sensor is still good. Any decent tire shop should have that tool if you don't want to buy your own. It's possible that Tire Rack activates the sensors but you'd have to ask them.
  10. Jun 6, 2017 at 11:59 AM
    Hiluxski
    Ventura California
    The idea with the Schrader programmable sensors are you program the new sensors to match your old sensors so you could switch wheels without any reprogramming , they just clone your original ID numbers from your original sensors. It's a great idea. So the new Schrader way you program the sensor not the truck
  11. Jun 6, 2017 at 1:26 PM
    Joe23
    did it work?
    when I emailed ATEQ about it they said it currently doesn't work with 2016+, this was back in februrary though.
  12. Jun 6, 2017 at 2:57 PM
    RichVT
    Rich
    Northern Vermont
    Yes it works. I used it for the first time last fall when I put my winter wheels on and again this spring when I switched back to my summer wheels.
    Joe23 likes this.
  13. Jun 12, 2017 at 1:40 PM
    ncoutu
    nic
    Update. Sullivan tire set up my new tpms's when I went for the alignment. They didn't even charge for it.
  14. Jun 12, 2017 at 4:32 PM
    ScottyR
    ScottyR Well-Known Member
    Vancouver BC
    2016 DCLB TRD Sport
    I just bought 4 new tire sensors and they don't work. Company that installed them suggested I go to Toyota....
  15. Aug 2, 2017 at 12:02 AM
    mrjoshyman
    mrjoshyman Well-Known Member
    Josh
    BUMP. i'm also looking for aftermarket TPMS to have installed in some new wheels/tires. i was quoted at $40/TPMS from Discount Tire....looking for something cheaper than that on Amazon or eBay that is: a) compatible b) plug-and-play
