Aftermarket Traction Assist
Discussion in 'Technical Chat' started by jhsfxrt, May 22, 2008.
  1. May 22, 2008 at 4:51 PM
    jhsfxrt
    jhsfxrt [OP] Member
    Pittsburgh
    08 Access Cab SR5 2wd 2.7 5sp
    :confused: Has anybody installed any aftermarket traction assist devices (limited slip , posi , locker, etc. ) in a 2wd , 4cyl truck. Mine has the factory installed 'wrong wheel drive'.
  2. May 22, 2008 at 4:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    There have been lots of people that have installed one of these in a Tacoma. Lock right is a popular one. Personally, if you just need a Limited slip, I think the Detroit True Track is a good unit.
  3. May 25, 2008 at 7:35 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Some people have bought $35 helper springs from Autozone, etc and mounted them backwards. Has the effect of limiting axle wrap and wheel hop so you get better traction. Also, getting stiffer rear suspension helps (lift or TSB if you can), but at $35 or so the helpers are the cheapest option.
