Aftermarket Transmission Cooler Installation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ggparts, Jun 12, 2009.
  1. Jun 12, 2009 at 7:37 AM
    ggparts
    ggparts [OP] Member
    Ottawa, Ontario Canada
    08 Access Cab SR5 Automatic 2WD
    Trifecta Tonneau Cover
    I want to add a cooler to my 08 4 cylinder, can anyone tell me which one of the lines is the "hot" or "cooled" so I can know where to put my cooler.
    PS any suggestion as to whether I should put it "before" of "after" the fluid passes through the rad?
    Thanks,
    Gerry
  2. Jun 12, 2009 at 10:46 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    The whole reason the trans oil passes through the radiator is because the radiator is cooling the oil. Its called a water cooled oil cooler. If you really want to add another oil cooler I guess you would just add an air cooled oil cooler after the oil exits the radiator.
