Aftermarket TRD Pro grill identification
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sigep481sean, Feb 13, 2024.
  1. Feb 13, 2024 at 2:53 PM
    Sigep481sean
    Sigep481sean [OP] New Member
    I just bought my TRD off-road and have started down the rabbit hole of blacking everything out on the exterior, and part of that was replacing the silver Toyota letters in the existing TRD pro style grill. I bought replacement letters that individually screw in place, like most options, however when I went to change them out I realized that my Toyota badging is a one piece panel and the letters don’t come off. I should also note that I couldn’t find any markings on the inside that would give me any indication.
    My question is does anyone know what brand of grill this is so I can order the correct blacked out replacement?
    allelopath likes this.
  2. Feb 13, 2024 at 3:43 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    Why not paint the letters black your self . Cheaper and you don’t have to chase anything down
  3. Feb 13, 2024 at 3:49 PM
    Sigep481sean
    Might be my only option, but I haven’t plasti dipped or painted any car parts before so I was concerned with longevity.
  4. Feb 13, 2024 at 4:03 PM
    TruckGuy63
    Gilbert
    New York
    I wouldn’t use dip, i would scuff it , clean with alcohol , and paint it . You can even put a coat of satin clear coat .it should hold up fine if you do right.
    allelopath and Sigep481sean[OP] like this.
  5. Feb 13, 2024 at 4:35 PM
    Sigep481sean
    Awesome. Thanks!
  6. Feb 13, 2024 at 4:47 PM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Falken Rubitrek AT 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    I ordered knock off grille with screw on letters that I did not think screws were adequate, so I used a toothpick and some jb weld where the letters touched the back of the frame. I also put some jb in the screw holes, so they aren’t coming off. I ordered letters that matched my gray Tacoma. If I want blackout or touch up, I’ll just tape, sand, prime and paint. If I change mind on grille, plenty of cheap knock offs in various styles out there. Painting the letters should work for your needs. If you do it right, nobody would know.
    TacoTime55 and Sigep481sean[OP] like this.
  7. Feb 13, 2024 at 9:39 PM
    kalaikanui
    kalaikanui Active Member
    Las Vegas Nevada
    2022 Tacoma Trd Sport
    In process: FN Wheels w/ BFG K02's, Bilstein 2/1 lift, Pro grille, tint
    I third the "paint job" solution... Flatten a couple of those Amazon shipping boxes everybody has laying around to use for masking behind the grille and spray that thang...
    Sigep481sean[OP] likes this.
  8. Feb 14, 2024 at 10:58 AM
    TheDanimal
    TheDanimal Well-Known Member
    Daniel
    DFW
    2024 Silver TRD OR 6MT 2019 MBM TRD OR 6MT (RIP)
    You could also order the TRD Lift Kit Grille. Its all black. If you look at my picture you'll see what it looks like.
  9. Feb 14, 2024 at 3:47 PM
    TruckGuy63
    Gilbert
    New York
    That is true
    Good catch
  10. Feb 14, 2024 at 3:54 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Did you check to see if the silver letter portion isn’t just held on with 3m tape. I’ve seen a few down that way.
  11. Feb 14, 2024 at 4:02 PM
    Sigep481sean
    Unfortunately they are integrated into the plastic like the OEM version
  12. Feb 14, 2024 at 4:23 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    I used the screwed letters and they've stayed in-place since Aug/2022.
    I ordered gray letters and Smoked Amber Lights.
    I added the 3-stripe thingy and I like how it's turned out.
  13. Feb 16, 2024 at 6:23 PM
    Losv
    Losv Active Member
    2019 Tacoma TRD Off Road 4x4
    When I painted mine, i had to mask around the letters. I did everything to color match, except the honeycomb grille. Was a lot of work but it stands out.
  14. Feb 16, 2024 at 6:25 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    That's a glossy effect...matches the color of your truck.
  15. Feb 16, 2024 at 7:31 PM
    Truv6
    Truv6 Well-Known Member
    Martin
    Castro Valley, CA
    2023 White Tacoma TRD Sport
    Wow that looks slick!
  16. Feb 16, 2024 at 9:26 PM
    bryan83taco
    bryan83taco Well-Known Member
    Hawai’i
    2023 TRD Sport 4x4
    I just installed Tacoma Troop's blacked out basic version. Good quality, easy install. The Toyota emblem screws in to the grill.
    TacoTime55 likes this.
  17. Feb 17, 2024 at 5:54 AM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    Good morning.
    Is the emblem one piece or is it individual letters?
    EDIT: I saw your post today on another thread with pic. (10:03am)
  18. Feb 17, 2024 at 7:42 AM
    Mystery252
    Mystery252 Well-Known Member
    I think the pro grille insert from Taco Vinyl should work for you
  19. Feb 17, 2024 at 5:49 PM
    bryan83taco
    Hawai’i
    2023 TRD Sport 4x4
    It's a one piece emblem, not individual letters. Good quality. Screws in on the backside with four screws.
    TacoTime55[QUOTED] likes this.
