Aftermarket tweeter wiring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ToyotaRacingDev, Dec 12, 2018.
  1. Dec 12, 2018 at 9:20 AM
    ToyotaRacingDev
    ToyotaRacingDev [OP] 425,000km
    London, Ontario
    2008 Tacoma TRD Sport
    So I leave it in this configuration? Or change
  2. Dec 12, 2018 at 9:20 AM
    ToyotaRacingDev
    London, Ontario
    Okay one minute
    Tweeter
    https://www.amazon.ca/gp/aw/d/B002X786Y0?psc=1&ref=yo_pop_mb_yo_pop_mb_pd_t2
    6.5 Speakers
    https://www.amazon.ca/gp/aw/d/B00BF6HWCM?psc=1&ref=yo_pop_mb_yo_pop_mb_pd_t2
    Wiring harness for 6.5
    https://www.amazon.ca/gp/aw/d/B0002BBP7Y?psc=1&ref=yo_pop_mb_yo_pop_mb_pd_t2
    I haven’t installed the stereo yet but this is the one
    https://m.aliexpress.com/item/32947...d=8313amp-7Xz6AWmErSWHztMNT-d-tw1544635716461
    Thank you very much to everyone in this thread taking time out of their day to help me out. I would be pulling my hair out if I didn’t have a community like this to ask questions in
    Do I need an amplifier as well? I’ve heard of people blowing out their speakers because that didn’t have one. I’m not planning on putting a subwoofer in
  3. Dec 12, 2018 at 9:40 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    top single red and black's those go to the tweeter? If so flip them. 2 blacks from the grey plug go to the positive of the tweeter, and 2 reds go to the negative.
    You can see when you plug that plug into the door harness that the blacks actually go to the pink's which are the positive of the main speaker.
  4. Dec 12, 2018 at 9:42 AM
    nd4spdbh
    SoCal
    Should be a pretty good setup. Id be inclined to do a 6x9 up front as you can fit them in easily with the proper adapter. But if you already have the stuffs go for it.
  5. Dec 12, 2018 at 9:46 AM
    ToyotaRacingDev
    London, Ontario
    Okay so you’re saying the black from harness goes with red on tweeter? And red from harness with black on tweeter?
  6. Dec 12, 2018 at 9:46 AM
    ToyotaRacingDev
    London, Ontario
    Already have the stuff, I might get one later down the road and put the 6.5 in the rear of double cab
    Should I be doing any crossovers or am I fine as is
  7. Dec 12, 2018 at 9:47 AM
    nd4spdbh
    SoCal
    Yup yup!
  8. Dec 12, 2018 at 9:48 AM
    ToyotaRacingDev
    London, Ontario
    Thank you very much for the help again, I cannot stress enough how helpful it’s been. Should I do crossovers or leave it as is
  9. Dec 12, 2018 at 9:49 AM
    nd4spdbh
    SoCal
    Did crossovers come with the setup?
    Looks like those tweeters have crossovers built in so you wont need them.
    Just make sure to get the positive n negative on the main 6.5's proper (I think the adapters have different sized connectors so you cant mess that up)
  10. Dec 12, 2018 at 9:52 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    U don't need to buy an adapter actually.
    Just gut the stock basket, bolt/screw new 6x9 to the OEM basket u gutted, screw the whole assembly right into stock location with stock screws.
    TNToyo79 likes this.
  11. Dec 12, 2018 at 9:54 AM
    81shark
    81shark Well-Known Member
    I ran new wires for all the speakers. For the tweeter holder, i reused the stock bracket.. Ripped out the factory tweeter and mounted my new tweeter to the metal bracket. Worked like a champ
  12. Dec 12, 2018 at 9:55 AM
    nd4spdbh
    SoCal
    Yeah you could do that, but for like 11-15 bucks for the adapter it wasnt worth my time
  13. Dec 12, 2018 at 10:00 AM
    ToyotaRacingDev
    London, Ontario
    No, I thought crossing over was something you did with the original cables. I guess it didn’t come with the setup. Setup sounds fine form 6.5 but still static from tweeter unfortunately. This is my first time wiring speakers as you can tell
  14. Dec 12, 2018 at 10:05 AM
    nd4spdbh
    SoCal
    Crossovers typically come with a matched component speaker system. The 3way 6.5 and the stand alone tweeter all have crossovers built into the speaker itself to clip the sound ranges that the individual speakers cant reproduce. You are good just wire them up as discussed and you will be good.
  15. Dec 12, 2018 at 10:13 AM
    #35
    ToyotaRacingDev
    London, Ontario
    Thank you very much, when someone says 3-way, 4-way, 5-way is that referring to crossovers
  16. Dec 12, 2018 at 10:28 AM
    #36
    nd4spdbh
    SoCal
    3way / 4way will refer to how many speaker components are within the speaker. A typical "3way" will have a woofer (for lows) a mid sized driver for mid range, and a tweeter for the high range.
  17. Dec 12, 2018 at 1:11 PM
    #37
    ToyotaRacingDev
    London, Ontario
    i’ve heard kickers are very good speakers, these fosgates are okay but not great
