Aftermarket UCA greasing question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by T1089, Mar 17, 2019.
  1. Mar 17, 2019 at 3:56 PM
    T1089
    T1089 [OP] Well-Known Member
    Tristan
    B.C. Canada
    2017 Tacoma TRD Sport 6MT
    -Bilstein 5100's EXT + 886 OME coils -Bilstein 7100 14"SB shocks -Camburg Uni ball UCA's -BAMF leaf hanger & shackle -BAMF shock relocation kit -Dakar HD leafs -U-bolt flip kit/super bumps -TRD PRO SEMA rims + 255/80/17 Ridge Grapplers -Cali Raised Led 32" hidden light bar & switch panel - Backflip tonneau -Demello tube sliders -Mobtown skid -TRD Pro grill -Custom bed rack -OVT 2.0 SFOB Tune -2WD Low mod -Kicker CS Speakers
    hello,
    I have a 2017 Tacoma with camburg uni ball UCA’s. When doing my maintenance everything goes smoothly. Loosen through bolt and pump grease through zerks till clean grease come out from around the bushing. Then I retorque with truck on the ground and I clean everything off. After driving around there is more grease around the bushing and enough so that it periodically drops into the frame. Even after cleaning it up again this will happen a few more times. Is this normal or is the uca under too much pressure from over lubricating or the through bolt not tight enough.
    -One last bit of info my UCA bolt is in backwards.
  2. Mar 17, 2019 at 4:00 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    What grease are you using?
  3. Mar 17, 2019 at 4:10 PM
    T1089
    Tristan
    B.C. Canada
    I can’t recall the name but it’s the brand that TC recommended from there video/same as the original install packets. It’s like as I’m driving the movement allowes some expelling of the extra grease?
  4. Mar 17, 2019 at 4:31 PM
    T1089
    Tristan
    B.C. Canada
    Bump
  5. Mar 17, 2019 at 7:02 PM
    T1089
    Tristan
    B.C. Canada
    Bump
  6. Mar 17, 2019 at 8:30 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I’m not sure what your question is, does extra grease come out? Sure
    whatstcp likes this.
  7. Mar 17, 2019 at 8:53 PM
    T1089
    Tristan
    B.C. Canada
    It was about 85ftlbs, my question is it normal/ok to have grease coming out of the bushing on my UCA after greasing description in OP
  8. Mar 17, 2019 at 8:58 PM
    T1089
    Tristan
    B.C. Canada
    I torqued to 85, I couldn’t remember exact number uca’s asked for but it was 80-85 iirc
  9. Mar 17, 2019 at 9:57 PM
    peppinoss
    peppinoss Well-Known Member
    Los Angeles
    2016 TRD OR 4x4
    ToyTec Boss 2.0 lift TRD Pro Wheels 265/70/R17 KO2s Mobtown Offroad Sliders
    It happens on mine. No issues so far. I stopped using the superlube stuff TC recommended because I kept having to grease every couple weeks. That stuff seems to turn very thin at low temps. I use green grease now and only grease every 6 months or so. I put the grease in, drive for a day or so and then wipe off any grease that seeped out. All good
  10. Mar 17, 2019 at 10:01 PM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Standard . Was some remaining pressure. As you exercised the UCA it burped it out. That's all. Use less grease next time. Not a big deal though
