Aftermarket UCA wheel fitment question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tucker771, Apr 2, 2017.
  1. Apr 2, 2017 at 9:29 PM
    Tucker771
    Tucker771 [OP] Tacoma Beast
    Tucker
    Raleigh, NC
    2004 Tacoma Doublecab 4x4 TRD
    Gray wire mod, 4" coil lift, 2" block lift+2" AAL, rear air bags, re-located trailer wiring plugs, trail gear front bumper, kicker sound w/pioneer in-dash, 8" kicker sub, airaid MIT kit, trail gear rock sliders, arrow antenna, blacked out grille, HID kit, Smittybilt 8k winch, extended brake lines, LED overhead lighting, LED turn signals, Explorer Rock Lights, removable doors, Re-wired 4x4, Roof Rack
    I am looking at purchasing some camburg, icon, or Total chaos upper control arms for my taco. On their product description, they say it fits with stock wheel sizes. My question is if they will fit with a 15" wheel or not? Trying to cover my bases before purchasing...
  2. Apr 2, 2017 at 9:37 PM
    Dimestore55
    Dimestore55 Well-Known Member
    William
    Richmond, VA
    2016 TRD OR 4x4 DCSB
    I don't think the diameter matters, it's the backspace and offset that determines whether the wheels will rub or not.
  3. Apr 2, 2017 at 9:40 PM
    Tucker771
    Tucker
    Raleigh, NC
    do you know what the minimum backspacing required would be?
  4. Apr 3, 2017 at 8:25 AM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    I don't believe aftermarket upper control arms will cause rubbing on the control arms if that's what you mean, as far as gaining a small amount of travel, you may rub the inner fender wells, fenders, or bumper if you run 33's and a safe go to for back spacing is usually 3.5"
  5. Apr 3, 2017 at 10:21 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    also make sure the 15's you're getting don't interfere with the calipers. some are known to rub. reason for 15's?
  6. Apr 3, 2017 at 10:34 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    youl have more clearance with a uniball actually.
  7. Apr 3, 2017 at 10:52 AM
    Tucker771
    Tucker
    Raleigh, NC
    I already have the 15"s. I belive they are a -19 backspace but i could be wrong.
