Aftermarket Upper control arm question. Please advise
Discussion in '1st Gen. Tacomas (1995-2004)' started by bodhi armor, Nov 27, 2016.
  1. Nov 29, 2016 at 10:36 AM
    #41
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    It's stainless steel on a teflon like coating, so kinda like metal on plastic, really shouldn't make any noise. I think the whole lubing thing started because people were concerned about corrosion on the uniballs? That's why you buy the good ones like TC/Icon with the stainless uniballs. Cheaper ones use steel that will corrode and rust. Lubing them can actually cause the teflon to kind of soak up the lubricant and it will break down and almost shred like fabric. Done made that mistake.
    Again most of the noise comes from the bushings, which most people probably DON'T grease properly, as you are suppose to loosen the through bolt and grease until it comes out, then tighten the bolt back up with truck on the ground.
    lynyrd3 and 04yota like this.
  2. Nov 29, 2016 at 10:46 AM
    #42
    04yota
    04yota Well-Known Member
    Angelo
    Central New Jersey
    04 ext cab supercharged 5speed
    You get what you pay for. Going With something high end will give high end results. I hear good things about built right, so will give them a call before placing my order
  3. Nov 29, 2016 at 9:17 PM
    #43
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Do you actually have any personal experience with uniballs on your rig?
    lynyrd3 and Adventurer_Alex like this.
  4. Nov 29, 2016 at 9:28 PM
    #44
    bodhi armor
    bodhi armor [OP] 02’ Dbl Cab- "The Luck Dragon"
    Joshua
    East TX
    2002 4x4 Dbl Cab Jade Green
  5. Nov 30, 2016 at 6:55 AM
    #45
    gottaToy
    JJ
    1985 Moped
    Yes, and I've have replaced them a few times, also. I also wheel pretty hard.
    lynyrd3 likes this.
  6. Nov 30, 2016 at 7:07 AM
    #46
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    So much want in this pic :drool:
    Delta00[QUOTED] likes this.
  7. Apr 28, 2017 at 1:52 AM
    #47
    1HItaco
    1HItaco Well-Known Member
    can anyone confirm that the LR is fully compatible with the extended travel coilovers like the uniballs? If they are what are the advantages of the uniball type vs the LR/SPC uca?
  8. Apr 28, 2017 at 2:01 AM
    #48
    Texas T
    Texas T Well-Known Member
    TX
    '14 T Force
    I've had the Built Rigth for almost three years now and would buy again. I don't jump or extreme off-road but what I know is my alignment is easily accomplished and I have sharp looking UCA's
  9. Apr 28, 2017 at 2:10 AM
    #49
    1HItaco
  10. Apr 28, 2017 at 2:17 AM
    #50
    Texas T
    TX
    '14 T Force
    The only advantage of the LR, in my opinion is the price. They are the entry level and a decent product but for not much more the built right are way nicer.
  11. Apr 28, 2017 at 2:31 AM
    #51
    1HItaco
    thanks for the input. any input on the travel capabilities of the LR uca's? are they also compatible with the long travel coilovers
  12. Apr 28, 2017 at 2:33 AM
    #52
    Texas T
    TX
    '14 T Force
    Probably not. If you are going LT get the LT gear.
  13. Apr 28, 2017 at 3:12 AM
    #53
    1HItaco
    not sure if the icon "extended travel" coilovers are considered a LT coilover?
  14. Apr 28, 2017 at 3:23 AM
    #54
    Texas T
    TX
    '14 T Force
    In my opinion if someone buys premium shocks/suspension they should buy the same quality UCA's and not the LR's. Nothing against them but let's match parts.
    Ritchie and lynyrd3 like this.
  15. Apr 28, 2017 at 3:48 AM
    #55
    lynyrd3
    Bill
    East Central Upstate NY
    Total Chaos
    Dwish and Ritchie like this.
  16. Apr 28, 2017 at 4:24 AM
    #56
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    not sure if you got your answer after but lr/spc ucas ARE compatible with ext travel coilovers.
  17. Apr 28, 2017 at 6:17 AM
    #57
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    They are considered a mid-travel setup.
  18. Apr 28, 2017 at 8:03 AM
    #58
    Digiratus
    Roaming the PNW
    The RedHead
    Not sure what your definition is of a long travel coilover is. Is it simply more travel than stock? If so, the typical definition is mid travel, not long travel.
    Long travel kits include upper and lower A arms that change the location of the pivot points and the shock mounting points. Light Racing's UCAs are not compatible with any long travel kits that I am aware of.
  19. Apr 28, 2017 at 10:33 AM
    #59
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    I have LC UCA arms and extended travel icons. I have about 60K hard off-road/on road miles on this setup and I'm on my second pair of LR's (previous truck). They're great; noiseless and maintenance free. I've never felt the need to "upgrade" to uniballs.
  20. Apr 28, 2017 at 11:14 AM
    #60
    McMash
    McMash The only thing better than light bars? Sarcasm.
    Tyler
    Gig Harbor, Wa.
    '04 Tacoma AC TRD 4x4
    Like I stated in the post you quoted, along with others and Google as well, LR UCA's are totally compatible with extended travel coilovers. Many people run this setup, including myself. They are a great option for standard or extended/mid-travel setups. They are not for long-travel. Do not confuse extended/mid travel with long travel; those are two totally different setups with different equipment.
