Aftermarket wheel fitment question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Adam3612, May 8, 2012.
  1. May 8, 2012 at 6:41 PM
    Adam3612
    Adam3612 [OP] Member
    Halifax, NS
    '11 Double Cab TRD Sport
    Undercover SE Tonneau WeatherTech Floor Liners
    I've searched and I can't really find the answer i'm looking for. I want some new wheels for my Tacoma, already checked and my current tires (265/65/17 Dynapro ATm's) will work with the wheels I want. My only question is will these wheels fit without any issues? Backspacing is 5.5", lug pattern and width are good the only thing i'm not quite sure about is the 18mm offset. Any info is much appreciated.
    P.S. Will any TPMS sensor work with the Toyota system or do I need Toyota specific sensors?
    http://www.discounttiredirect.com/d...11&pc=22566&counter=1&wd=17&rw=8.5&vid=019279
  2. May 8, 2012 at 6:49 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Only the stock TPMS sensors will work with your car. The TPMS module is coded and linked with the factory set, so it will not read any other code.
  3. May 8, 2012 at 6:56 PM
    Adam3612
    Halifax, NS
    Ok, thank you for the info. Looks like my summer set of wheels and tires is gonna go without TPMS sensors lol. Any idea if the 18mm offset on the wheels I want will create any issues?
  4. May 8, 2012 at 11:01 PM
    The Traveler
    SoCal
    To be honest, I don't know much about the offset these trucks can take, because I just got mine last week! But I did swap my wheels out and that's how I know the TPMS wont work with it. Only thing you can try is swapping the sensors. I have that damn light on all the time now.
  5. May 9, 2012 at 11:35 AM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    the 18mm offset will fit fine with that tire size you listed. it's going to sit 1" out more than stock. if you go with a wider tire in the future, you might run into clearance problems on the inside, but a spacer/adapter to push it out for a more aggressive look should take care of it.
  6. May 9, 2012 at 4:51 PM
    Adam3612
    Halifax, NS
    Right on! Thanks for all of your input I really appreciate it, now i've gotta go see if a friend can get me a sweet deal on the wheels or if discount tire is my best option lol.
  7. May 9, 2012 at 5:13 PM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    For you to have those specs, you would have to have a 17x8.5 rim. Given that you plan on installing the same size tire, you would be pushing your set up out .6" (14mm) from stock.
  8. Jun 11, 2012 at 1:48 PM
    Adam3612
    Halifax, NS
    Waited too long to order the vtec's now i'm having a hard time finding a set of them in stock or a place that can give me a time frame on when I can get them. I decided to look at alternatives and I like these as much as the vtec's....
    http://www.daleearnhardtjrwheels.com/item.php?cat_id=160&item_id=1430&scat_id=111
    I'm staying as close to stock wheel specs as I can and i'm also gonna stick with stock tire size. I know the backspacing and offset should work but what about the hub bore? I've read several posts on here that say hub bore on our trucks is 108mm i've also read several posts that say its 106mm. Anyone see any reason why these wheels wouldnt fit without any issues?
  9. Jun 11, 2012 at 2:59 PM
    Dromlace
    Dromlace Well-Known Member
    Michael
    Montgomery, AL
    2006 Tacoma TRD Sport
    I say hold out until SCS wheels make their debut :)
  10. Jun 11, 2012 at 5:29 PM
    Adam3612
    Halifax, NS
    SCS wheels do look pretty sick but I still think i'm gonna go with the Dale Jr. Ribelle's if they fit properly. I wanted to put them on the '08 Jeep Wrangler I had before I got the Tacoma but I couldnt justify it because they would have taken a beating off road.
  11. Jun 12, 2012 at 11:06 AM
    Adam3612
    Halifax, NS
    Anyone?
