Aftermarket wheel fitment
Discussion in 'Wheels & Tires' started by hetkind, Feb 12, 2011.
  1. Feb 12, 2011 at 8:34 AM
    hetkind
    hetkind [OP] Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I got my '11 Tacoma Access Cab 4x4, SR5 last week with the 245/75R16 tires and ordered a set of wheels for my snow tires, in the 245/70R17 Size.
    However, the wheels, 17x8, 6 on 5.5 4.5" bs interfere with the brake caliper...Crager Black D window wheels looking sort of like this...
    will light grinding of the caliper fix this or do I need to find different wheels that do fit.
    Howard
  2. Feb 12, 2011 at 8:38 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Are you asking if you will rub or are you rubbing?
  3. Feb 12, 2011 at 8:43 AM
    hetkind
    Howard
    Johnson City
    Not just a rub...with the wheel bolted in place, solid interference against the caliper with a no turn condition.
    Howard
  4. Feb 14, 2011 at 3:42 AM
    hetkind
    Howard
    Johnson City
    I think I have answered my own question here...
    Wheel rubs exist and are well known and documented and here is a low buck solution...
    scroll down for the $5 1/4" wheel spacers...
    Howard
  5. Feb 14, 2011 at 3:47 AM
    Ace83
    Ace83 Well-Known Member
    TX
    SR5
    Bilstein Front shocks, Rough Country 3" lift kit, 5" black railway running boards
    yup spacer will be an easy and better fix
  6. Feb 14, 2011 at 4:23 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    The spacer is the easy way, but if that doesn't work, some have actually lightly ground the caliper to cure the rubbing.
  7. Feb 14, 2011 at 5:09 AM
    hetkind
    Howard
    Johnson City
    not grind, POLISH...
    Howard
