Aftermarket Wheel Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pootermobile, Dec 5, 2010.
  1. Dec 5, 2010 at 10:24 AM
    pootermobile
    pootermobile [OP] Well-Known Member
    Florida
    06 DBL cab 4WD V6 6-speed Debadged
    De-Flapped, All-Weather Floor Mats, Blue LED dome light, De-badged, BMW shift knob, 8K HIDs in headlights and fogs, Fog light relay MOD, 3" Coil-spring spacers, 1.5" rear blocks, 17" ProComp 7033s, 285/70R17 Nitto Terra Grapplers, Ebay 7" touch screen head unit, TEKstyle snap button tonneau cover
    Does anyone know if the Pro Comp Rock Crawler Series 52/series 98 Steel wheels will fit on an 06 tacoma? If so, which sizes? I understand some wheels have problems hitting the outsides of the front calipers and i was wondering if these had the correct offset/backspacing needed to clear. Has anyone tried this? i've searched all over and of course 4wheelparts says they have the right lug pattern so they will fit but i just want to hear from someone that has done it to be sure before i order them. thanks
  2. Dec 5, 2010 at 10:27 AM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I know for sure that 15" wheels won't work, and I have heard of some 16's not fitting because of the brake caliper. Your offset would need to be 0 or -12 (not quite sure which one) and your BS would need to be 4 or 4.5".
  3. Dec 5, 2010 at 10:54 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
  4. Dec 5, 2010 at 11:35 AM
    pootermobile
    Florida
    Thanks Colton
