Aftermarket wheel questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaJoe22, Oct 31, 2020.
  1. Oct 31, 2020 at 2:59 PM
    TacomaJoe22
    TacomaJoe22 [OP] Member
    Joe
    2013 Charcoal Gray TRD Off Road
    Hi All,
    New to the forum. Glad to be a part of your group!
    I have a wheel question. I have a 2013 TRD Off Road. I want to stay with the stock suspension, not looking to lift. I’m going to go with Duratrac 265/70/17s. I’ve had great experience with them on multiple vehicles. From what I understand, this size should fit with minimal to no rubbing. I have removed front mud flaps and wind deflectors. I currently have 245/70/17s on my Taco with nearly 80k on them.
    I’m having a difficult time finding a wheel, that I like, that will fit in regards to bolt pattern, backspacing and width. I wanted the Black Rhino Armory wheel, but I’m told that they only have it in 9.5 width, and that will rub badly with this tire and wheel combo.
    Any suggestions for what width is best to run on my Tacoma with the 265/70/17 Duratrac? I’m thinking 8 or 8.5? Also, any suggestions on a nice, non glossy, black wheel that may be a better fit? I’m a fan of the Black Rhino Armory and Garrison. I like more coverage, less open space. Any help or advice would be appreciated. Thank you in advance!
  2. Oct 31, 2020 at 3:04 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Why not the 16x8 version of the Black Rhino Armory and a 265/75R16 Duratrac?
  3. Oct 31, 2020 at 3:12 PM
    TacomaJoe22
    Joe
    I was under the impression that a 16” wheel wouldn’t clear the brakes for my vehicle. I would be open to that setup, if it will fit on my 2013. I’ve been told by a few people, that I may have to stay with a 17” wheel.
  4. Oct 31, 2020 at 3:19 PM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    My 15 Off Road came with 16s stock.
    hoarder23 likes this.
  5. Oct 31, 2020 at 3:19 PM
    Bishop84
    Bishop84 Well-Known Member
    All tacomas fit 16"s Only 4runner needs 17's.
  6. Oct 31, 2020 at 3:20 PM
    hoarder23
    Shay
    NJ
    Scratches
    Do you drive a 4Runner? Or have you installed 4Runner brakes on your truck? Tacoma TRD Off Roads come from the factory with 16" wheels.
  7. Oct 31, 2020 at 3:28 PM
    TacomaJoe22
    Joe
    Thank you for the help. My stock wheels were taken off at time of purchase. They were sold to a friend right at the dealer. I had my wheel and tire setup, from a previous vehicle, put right on. I had Moto Metal Skull wheels 17” with the 245/70/17 Duratracs put right on.
    So if I was to go with a 16x8 wheel, which I would be perfectly happy with, what is the largest Duratrac that I should be able to fit without rubbing? 265/70/16? Seems like that would be the option.
  8. Oct 31, 2020 at 3:30 PM
    hoarder23
    Shay
    NJ
    Scratches
    If you look at the specs page for the tire you I tend to purchase you can see all the info about them. 265/75R16 is the same outside diameter as the 265/70R17 you mentioned in your first post.
  9. Oct 31, 2020 at 3:36 PM
    Minny Taco
    Minnesota
    I put 265/75/16 Toyos on mine,that's a touch bigger than stock. I had to remove the little mudflap in front of the front tire because it rubbed. Not sure how much bigger you can go without issues.
  10. Oct 31, 2020 at 3:43 PM
    TacomaJoe22
    Joe
    Thank you. This is definitely the route I will go, moving forward.
  11. Oct 31, 2020 at 3:44 PM
    TacomaJoe22
    Joe
    That size should be perfect for what I want. I have removed the front mud flaps and that little flap in front of the tire as well. Thank you.
    Minny Taco[QUOTED] likes this.
  12. Oct 31, 2020 at 4:30 PM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
