aftermarket wheels and tires w/o lift pics please
Discussion in 'Wheels & Tires' started by PaulVthe3, Jan 8, 2009.
  1. Jan 8, 2009 at 5:38 PM
    PaulVthe3
    PaulVthe3 [OP] Well-Known Member
    Ive seen alot of pics with lifted and leveled 05+Tacomas, but does anyone have any pics with just aftermarket rims and tires? Right now I cant swing the lift, rims, tires, alignment, and the other expenses that come with a lift. But what I can do is grab a set of tires and rims to get my truck at least looking better for now. Ive got an 09 DC 4wd shortbed v6 speed way blue NON TRD and its begging to look better. Please include details such as backspacing, offset,rim size, the more the better.
  2. Jan 8, 2009 at 5:40 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    What type of rims and tires are you looking to get?
  3. Jan 8, 2009 at 6:13 PM
    PaulVthe3
    Im looking at moto metals or some mickey thompsons. I like the new side bitter rim. Im just trying to see what looks good on a stock suspension. I want a little wider and taller tire than the 245's. That's all for now.
  4. Jan 8, 2009 at 6:30 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Just make sure what ever wheel you buy will be compatible with a tire size you may want later when you lift. That way you just need new tires rather than the whole deal.
    I went with Bridgestone Dueler AT Revo's right off the lot. Great tires. Lifted my truck and sure enough needed to go bigger. So got 16x8's DC-1's, but knew that the AT Revo's @ stock size would irritate me, and 2 mos later I had new tires.
    Basically just plan for the long run, cause if you take sure cuts, it will cost more in the end. Good luck...
  5. Jan 9, 2009 at 12:36 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    You might want to post up some pictures of your truck along with the wheel you're interested in on the Photoshop thread. Most wheel rim pictures are slightly angled so try to get a picture of your truck at a similar angle otherwise the photoshop version can look a little odd. It's not always a perfect solution but you can usually tell if you're going to like the look.
    Here are instructions for posting a picture in a thread if you need it.
