Aftermarket wheels centerbore questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tntee, Sep 18, 2018.
  1. Sep 18, 2018 at 6:31 PM
    tntee
    tntee [OP] New Member
    2018 Tacoma Sr Accesscab
    Hey everyone!
    I recently purchased my brand new 2018 Tacoma Sr Access cab, and is looking to get some aftermarket wheels. I been doing online shopping, and had a couple wheels in mind.However I see that some wheels has a centerbore of 108.00mm, and some with a 106.25mm; but the filter still say both will fit my Tacoma? Can someone please tell me if I would need a hub ring to run these wheels or how they would fit with different size centerbore?
  2. Sep 18, 2018 at 6:39 PM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    You will get conflicting responses here. Do your own research on hub rings (both sides) and make your decision
  3. Sep 18, 2018 at 6:53 PM
    tntee
    So before after market wheels. I do have a questions about tires and fitting. I currently have on 245/70/16 stock hankook tires, and if I wanted to run 265/75/16 with stock height. Will there be any problems with rubbing?
    Ronzio likes this.
  4. Sep 18, 2018 at 6:53 PM
    Clearwater Bill
    Billy
    Largo Florida
    If the wheel has cone lug nuts and you know how to mount a wheel, the rings wont matter.
    They may make it easier though. After about my 3rd rotation on another marquee i threw mine away
    If the wheel uses flat bottom lug nuts, I'd use the ring
    Amanelot likes this.
  5. Sep 18, 2018 at 6:57 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    If you go to America/Discount Tires, they have a fitting chart. I believe 265/75/16 is suppose to fit according to that.
  6. Sep 18, 2018 at 6:59 PM
    Clearwater Bill
    Billy
    Largo Florida
    The specs of the wheels are critical to the answer.
    OE wheels will fit 255 85 16 w no rub. Full 33" The tire width and wheel spec allow this. Big thread on it.
    CaptainBart45 likes this.
