Aftermarket XM antenna for Entune
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cchoc, Sep 5, 2014.
  1. Sep 5, 2014 at 4:09 AM
    cchoc
    cchoc [OP] Wilderness Photographer
    Charlie
    Land of grits and gravy
    2015 Tacoma quad cab long bed
    I found on search how to use shark fin with aftermarket radio, but I am going to add a 4Wheel Camper to my 2015 Tacoma with Entune audio and nav and the fin will be covered so I am looking for a cable that will plug into the Entune and split the XM and nav to plug into aftermarket magnetic antennas.
    Does such a beast exist?.
  2. Sep 11, 2014 at 4:24 PM
    cchoc
    Charlie
    Toyota wants $460 to move the antenna, will try my local stereo stores.
  3. Sep 11, 2014 at 4:49 PM
    whiting1977
    whiting1977 Well-Known Member
    Sacramento CA
    2014 SR5 PreRunner
    Maybe move the Shark Fin on top of the camper?
  4. Sep 11, 2014 at 5:30 PM
    cchoc
    Charlie
    I'm going to look at moving it to the hood on the right side, then it will be available if the camper is not on. Still leaves a hole in the cab roof, though.
  5. Sep 11, 2014 at 8:53 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    I'm using the magnetic roof antenna with my factory xm sirus unit. I had to my a special connector. SMB to FAKRA
  6. Sep 12, 2014 at 6:50 AM
    cchoc
    Charlie
    Do you have GPS too?
  7. Sep 12, 2014 at 12:11 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    Yup. Im using a different antenna within the dash.
  8. Sep 12, 2014 at 2:06 PM
    cchoc
    Charlie
    Stereo shop set mine up today with two separate antennas on ether side of the base of the windshield. They used a Kenwood GPS antenna.
  9. Sep 13, 2014 at 4:53 PM
    cchoc
    Charlie
    Kenwood GPS antenna will plug into the head unit. The XM and GPS wiring to the shark fin is part of the cabin wiring harness and not easily relocated.
