Again,.... Annoying tire warning
Discussion in '2nd Gen. Tacomas (2005-2015)' started by whttaco2whl, Sep 10, 2017.
  1. Sep 10, 2017 at 6:06 PM
    whttaco2whl
    whttaco2whl [OP] Well-Known Member
    KC
    North of LA
    2009 Tacoma base model, 2Whl 5Lug
    None
    The symbol of the tire with an exclamation mark is tire pressure correct?
    Is it true the spare tire can cause it? I have checked all 4 on the car to be equal and set at 30 PSI. Can't get the warning to reset. Followed the owner's manual, but stays on steady. Also tried to reboot with battery disconnect,... No joy.
  2. Sep 10, 2017 at 6:08 PM
    medic2230
    Murph
    Bama! Roll Tide
    If your truck is old enough it could be one of the sensors died. It usually blinks when you start up and then stays on solid when that happens.
  3. Sep 10, 2017 at 6:10 PM
    Bishop84
    Bishop84 Well-Known Member
    Set it 4 psi higher, as they age they start to read wrong and like higher pressures I find. But it's also likely a sensor has failed, they have small batteries that eventually fail.
  4. Sep 10, 2017 at 6:53 PM
    whttaco2whl
    KC
    North of LA
    None
    Of Course! Sensor or it's battery makes a lot of sense, Thanks. BTW,.... Just to prove it to myself, checked the spare and it has a rubber valve stem so not a factor.
  5. Sep 10, 2017 at 6:57 PM
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    You can bypass it if you're inclined. Did it on mine and nice to never worry about swapping sensors or resetting the light
  6. Sep 10, 2017 at 6:58 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    What if I told you the answers to all your questions was located in a secret book in your glove compartment. It's a Toyota. If the light is flashing you got a problem. If it's steady on air up your tires and drive it. Light will go away
  7. Sep 10, 2017 at 7:06 PM
    whttaco2whl
    KC
    North of LA
    None
    Thanks for the Hot Tip BeBop. Did follow the book as I said............
    I would be interested in the Bypass / disable if there is a thread somewhere.
    theredofshaw likes this.
  8. Sep 10, 2017 at 7:28 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Holy shit. They make a book for these things? :eek:
  9. Sep 10, 2017 at 7:39 PM
    rollin904
    TJ
    Greenville, SC
    '14 DCSB 4x4
  10. Sep 10, 2017 at 7:41 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    OP what year is your truck. In 09 they got rid of the 5 sensor in the spare... so if its 05-08 the low pressure light is coming from the spare if you have the rest filled properly.
  11. Sep 10, 2017 at 7:50 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    A piece of duct tape pretty much fixes this problem
  12. Sep 10, 2017 at 8:07 PM
    whttaco2whl
    KC
    North of LA
    None
    I should have mentioned,....... It a 2009. Basic Reg cab.
    Hah! Duct tape! I did use black tape on the too bright Low Fuel warning on my motorcycle which was blindly bright at night.
  13. Sep 10, 2017 at 8:19 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    On some model years it reads the spare. My 07 does and adding air to my spare has turned the light off before in the past.
  14. Sep 10, 2017 at 10:30 PM
    TacoTrooper
    TacoTrooper Well-Known Member
    James
    Vancouver, Canada
    2013 TRD Double Cab 6-spd manual
    2013 TRD Sport DCSB 6-spd manual
    How much of a PSI drop triggers the warning light?
  15. Sep 11, 2017 at 7:27 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    TPMS per federal spec's is suppose to activate with a 25% drop in pressure from last reset. IE - set at 32 pounds, a loss of 8 pounds should make it light up.
