Aggressive looking all terrain tires?
Discussion in 'Wheels & Tires' started by zclic, Feb 7, 2018.
  1. Feb 8, 2018 at 5:34 AM
    #41
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Yeah, those or the MS2's.
  2. Feb 8, 2018 at 6:17 AM
    #42
    JaxJim
    JaxJim Well-Known Member
    Jim
    Jacksonville, FL
    13 TRD Sport, DCSB, 4x4, JBL, NAV
    Exterior: Duratrac 265/70/17, SpiderTrax 1.25" wheel spacers, BAMF sliders, DiamondBack SE Tonneau Cover, Pop&Lock, Tail Gate guard, Bed Mat, Bullaculla Trailer Harness bracket, Front Side Windows tinted to match rear, Removed all chrome and dealer badges, Toyota OEM Roof Rack/Rails, SOS Concepts Front Recovery bracket Under Hood: Redline Tuning Quicklift Hood Struts, Foglight anytime mod, UniFilter for Secondary Air Pump Interior: Seat bell Chime disable (TechStream), WeatherTech floor liners, ImMrYo rearview mirror relocation bracket, 12v Always-on Power port in console Radios/Comms: AntennaX 14", Escort Passport MAX Radar Detector, Yaesu 2900 Ham Radio, Uniden 980SSB CB Radio, Relentless Fabrication hood antenna mount, BAMF tailgate antenna mount, FireStik 2m and CB antennas, FireRing coax
    If you can afford them, then these are fantastic tires. I've had a few sets over the years and they are amazing for light offroad and stick like velcro on road wet or dry. But man are they proud of them!
    TacomaMike37 likes this.
  3. Feb 8, 2018 at 8:09 AM
    #43
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    This.
    I never understood the "i drive highway but want aggressive tire argument"
    Dhannah likes this.
  4. Feb 8, 2018 at 8:28 AM
    #44
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    That means most driving is done on the hiway,but also driving offroad also,do you really think all the offroader fanboys here spend most of their time offroad in their truck,B.S,they like everyone else are on paved roads for daily life like going too work 5 days a week.
    Keep on Truckin' and SLO/TACO like this.
  5. Feb 8, 2018 at 8:57 AM
    #45
    Pigpen
    Dan
    Northwest Montana
    Not all Tacomas are daily drivers. Mine is though, on 60 pound MT tires.
    BWilley likes this.
  6. Feb 8, 2018 at 9:00 AM
    #46
    Pigpen
    Dan
    Northwest Montana
  7. Feb 8, 2018 at 9:00 AM
    #47
    Zacowacko
    Zacowacko Well-Known Member
    Zack
    SW, OK
    2013 DCSB TE 4x4 6spd
    TRD Pro Susp., Icon AAL, Bags w/cradles, US OR Bumper w/Smitty, 2Lo Mod
    My Duratracs are cupping pretty bad, but its probably more the 5100's loading up the spring, with the addition of the bumper and winch. Not sure. Multiple alignments and road force balance didnt help. All suspension components in good shape. When these wear out, i will do a proper springs and shock, but will probably go with a different tire. When i was getting them balanced, there was another guy in there with a 2500 super duty with the same tire (higher load rated), doing the exact same thing. His truck was new, stock height. So i dont know.
    Anyone had luck with Terra Grapplers? Still want something semi-aggressive, but i am driving over 80 miles a day.
  8. Feb 8, 2018 at 9:06 AM
    #48
    Pigpen
    Dan
    Northwest Montana
    Cupping is alignment or tire pressure. You might need more air, or maybe a heavier tire. I haven't experienced cupping on my Tacoma with load E tires at 40 psi. I'm on my 3rd set. Just switched from Toyo M55s to Dean Backcountry MT.
  9. Feb 8, 2018 at 9:38 AM
    #49
    Zacowacko
    Zack
    SW, OK
    Done several alignments and balances, including road force. Checked all suspension components. A regarded suspension guy, said that loading up the springs with the 5100's, with the addition of the added weight of the tire, bumper, and winch are probably the cause. I have also tried mult air pressures, including chalk test. I'll just live with it until they wear out, at this point.
    Dont know what to think, but what he says does make sense. Will only know once i get a proper spring and shock in there and new tires. I can attest that the ride is much harsher, after loading all that up on the front end, with factory springs loaded up.
    I may give the Toyo's a try, if you have had good luck with those. My build was not entirely different from what yours was at one point. I even have firestone bags in the back, as well.
  10. Feb 8, 2018 at 9:44 AM
    #50
    2010tacoma2tr
    2010tacoma2tr Well-Known Member
    They make duratrac's in SL too, which would probably be better suited for OP's truck.
  11. Feb 8, 2018 at 12:18 PM
    #51
    nobescare
    nobescare Well-Known Member
    Mark
    43.5448° N, 80.2482° W
    2019 Highlander SE
    My 2005 prerunner had frame failure Aug 2024
    i've been very happy with my General Grabber AT2's.. Run them year round and amazing in the winter (with weight in the back).
  12. Feb 16, 2018 at 9:00 AM
    #52
    ejl923
    Eric
    Western Mass
    you dont have to take everything so literally. What i meant by this is there's a large contigent of drivers who drive highway most of the time and only want aggressive tires for looks. If its for looks, get over it. If you actually need aggressive tires then go for it.
    jsi likes this.
  13. Feb 16, 2018 at 4:47 PM
    #53
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    My vote is Firestone Destination AT.
    catastrofe likes this.
  14. Feb 17, 2018 at 8:24 AM
    #54
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    Thank you for your business, greeneggsnspam! We're glad to hear that your Cooper Discoverer ATP tires are still going strong on your fiancee's rig!
    The Discount Tire stores carry a variety of safe tires and they also guarantee the lowest out the door price! Contact your nearest Discount Tire and they will be happy to help you select the right tire model for your needs and uses!
    Store Locator | Discount Tire
    On a side note, today is the last day to take advantage of the in-store Presidents Day Deals!
    Thank you for choosing Discount Tire!
    Nice pick with the MB Choas 6 - love the silver, very sharp! Thank you for your support!
  15. Feb 17, 2018 at 1:44 PM
    #55
    tacobout_it
    tacobout_it Member
    i indeed ended up going to Discount Tire. Got a set of Michelin Defenders. Thankfully I scheduled an appointment so I was in and out within an hour, and got the $100 rebate. Always a good experience at Discount Tire.
    #55
  16. Feb 17, 2018 at 1:51 PM
    #56
    Discount Tire
    Arizona, USA
    That's awesome to hear, tacobout_it! The Defender is an awesome tire - I'm sure you'll enjoy it.
    Thank you for the shoutout to your local Discount Tire!
  17. Feb 17, 2018 at 1:59 PM
    #57
    lynlan1819
    Tacoma
    Lifted
    Can you post a picture please
  18. Feb 17, 2018 at 6:21 PM
    #58
    Geronimo1111
    Geronimo1111 Well-Known Member
    Ventura, Flagstaff & Phoenix
    '07 Silver Streak Mica 2.7L AC
    Ride-Rites LEER 100 XQ Cap Homemade Bedslider Bilsteins
    @moose knuckles - What BFG's are you running?
  19. Feb 20, 2018 at 4:04 PM
    #59
    DixonCreekDrifter
    DixonCreekDrifter Grey Headed Shop Teacher
    Dixon
    east of the Rio Grande and south of the Canadian
    Last Truck
    Stock for now
    Keep them inflated, rotated and balanced. They will be good for at least the advertised miles. Happy travels.
    Liked the way this thread ran, lots of experience shared to the poster who received lots of opinions and advice. First time I ever saw a vendor step in, but all he shared was information.
    Good job Tacoworld. That's why I stay on this forum.
  20. Feb 20, 2018 at 7:34 PM
    #60
    86scirocco16v
    86scirocco16v Mack of all trades
    Leavenworth, Washington
    '05 4.0 6sp overland
    Black this black that , 315-75r16 pro-comp A/T's , 285-75-r-16 treadwright gaurd dogs full OME lift with Dakar leaf spring pack, boss airbags, 4.88 nitro gears, dakota digital speedometer calibrator, tjm air locker, arb onboard air, spider tracks 1.25" wheel spacer, sport headlights, brute force fab hybrid front bumper, 6000k 4" led fog lights, 24" double row led reverse light, storm trooper shift knob, rebadged badg-less black mesh grill, Kenwood double din stereo, 400w Rockford 12” sub . Anytime fog lights. Oh yeah almost forgot the 2016 FourWheel camper fleet model for extra traction and a place to crash if you do get stuck or broke down. 2x160watt solar, mppt charge controller by blue sky energy. 3 deep cycle batteries 20gallons water, 6gal hot water, 3.5cf 2way fridge/freezer, 6gallon propane... just getting warmed up.
    I just picked up a set of Treadwright gaurd dogs and have been super happy with them. 4000 miles so far and wear is nice and even, considering my load and driving that’s great. For the price of $600 compared to my Toyo M-55’s at $1500 I wouldn’t hesitate again. They look cooler then the m-55 imo.
    Keep on Truckin' likes this.
