Aggressive vibration when accelerating
Discussion in '3rd Gen. Tacomas (2016-2023)' started by fredfarmer, Feb 22, 2021.
  1. Feb 22, 2021 at 6:54 AM
    fredfarmer
    fredfarmer [OP] Well-Known Member
    DFW
    2016 TRD Off Road AC
    2016 TRD Off-road auto transmission
    My truck has started intermittently vibrating when accelerating. The best I can describe it is when I was learning how to drive a manual. If you get it in the wrong gear it would start to vibrate. It doesn't seem to be related to the transmission shifting gears and only when accelerating. It also does it when ETC on and in 4WD - high. It also only does it after warming up.
    I searched and some said replacing the ATF is a fix, OV Tune is a fix or a $2500 TBS fixes it.
    Any of you folks have any experience with this?
  2. Feb 22, 2021 at 7:00 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    could be driveline vibration
  3. Feb 22, 2021 at 7:00 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    I don’t have anything really good to offer, but maybe it’s related to the fuel pump. Check out the recall and see if your truck is listed. Either way, good luck!
    If your lifted the driveshaft angles could be messed up and you might need a spacer on the carrier bearing.
  4. Feb 22, 2021 at 7:09 AM
    weeksz
    weeksz Well-Known Member
    Adam
    Traverse City, MI
    2017 DCLB Limited
    Stickers mostly
    Considering you mentioned it happens in 4WD, any chance you're off-roading when you feel the vibration, or your wheels are slipping?
    RedWings44 likes this.
  5. Feb 22, 2021 at 7:41 AM
    fredfarmer
    DFW
    I was just using FWD - high for the snow we had here in Dallas. I just dropped it off at Rockwall Toyota.
    No lift on the truck, but thanks for the info!
  6. Feb 22, 2021 at 7:57 AM
    weeksz
    Adam
    Traverse City, MI
    2017 DCLB Limited
    Stickers mostly
    I'm just wondering if the vibration is caused from your wheels slipping and causing wheel hop or axle wrap. Does it happen on dry pavement?
    Also you mention being in the wrong gear, you could be at too low of an RPM for your speed and the truck will "lug" causing a vibration.
  7. Feb 22, 2021 at 8:00 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Do any lights come on at all? It could be traction control kicking in from too much acceleration. Snow isn't like dirt so it's much easier to slip, especially if it is slushy snow.
  8. Feb 22, 2021 at 8:03 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Considering things that might bind (or want to bind) under load...check the condition of your driveshaft center support bearing/bushing. Other possibilities are U-joints or inner front CV joints.
  9. Feb 22, 2021 at 8:08 AM
    fredfarmer
    DFW
    No lights, it started happening before the snow so it'll do it on dry pavement. It's pretty aggressive and happens only when accelerating. Not tied to any certain speed, happens on residential and highway only after the truck has warmed up.
  10. Feb 22, 2021 at 8:56 AM
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    "Under a load" make one think clutches/bands are slipping ? ATF change may only be a short term fix.
  11. Mar 1, 2021 at 7:24 AM
    fredfarmer
    DFW
    Replacing the transmission seems to have fixed it.
  12. Mar 1, 2021 at 7:31 AM
    brandon78lusch
    Brandon
    damn
  13. Mar 1, 2021 at 7:35 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Under warranty?
  14. Mar 1, 2021 at 7:40 AM
    fredfarmer
    DFW
    Nope. About $5600 with front brakes as well.
  15. Mar 1, 2021 at 8:07 AM
    MauiBrian
    MauiBrian Kapalua fun
    Brian
    Maui
    2018 SR lightly modded
    Ouch! I'm wondering if your trans had the correct fluid level from the factory...
    How many miles and was the ATF ever changed on the original transmission?
    Just curious...
  16. Mar 1, 2021 at 8:12 AM
    Gearheadesw
    Davenport Fl
    Bummer, did they give a cause?
  17. Mar 1, 2021 at 8:52 AM
    Car Ram-Rod
    Car Ram-Rod Well-Known Member
    Wow
    wilcam47 likes this.
  18. Mar 1, 2021 at 9:05 AM
    fredfarmer
    DFW
    107k miles, never replaced the ATF. They said it had a hard shift between 4 and 5.
    Gearheadesw likes this.
  19. Mar 14, 2021 at 6:39 PM
    motogeek
    motogeek Taco Tueday? Tacos Everyday!
    Tacomeat
    America
    Tacoma SR5 TRD 4x4
    2.5 Toytech Inch Lift 285 Cooper SST
    I sure hope it was not just a bad CV on the driveline and got a transmission out of you. :( I'm about to go in for 60k and have a similar vibration that appeared. Pretty sure it's the tires out of balance. We'll see.. Going to inspect the driveline my self before taken in so I can have a baseline of my observations a.k.a (crack or split cv boot, grease or loose drive line cv).
  20. Mar 31, 2022 at 5:07 PM
    dimead0zen
    dimead0zen Well-Known Member
    So Cal
    Mid-Travel 2016 TRD Off-Road 4x4
    Desert prerunnin', rock crawlin' machine!
    Yeaaah I am experiencing the exact same feeling. About 1,500 RPMs at 10-30mph, feels like if you shifted too early and bog in a manual. I am about 90% sure it's a driveline angle issue, bad driveshaft or CV. We'll see.
    brandon78lusch likes this.
