aggrivated
Discussion in '1st Gen. Tacomas (1995-2004)' started by Clange1731, Dec 9, 2014.
  1. Dec 9, 2014 at 7:16 PM
    Clange1731
    Clange1731 [OP] Member
    Hayesville,nc
    03 prerunner trd
    Put my Bilstein/toytech 3" lift on and went to put my new wheels and tires on and they hit to UCA
  2. Dec 10, 2014 at 5:17 AM
    offrdmania
    offrdmania Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    Usually aftermarket lifts will require aftermarket wheels due to a greater offset needed to clear. Have you aligned it yet? A lot of times it will hit until it is aligned if its just barely hitting.
  3. Dec 10, 2014 at 5:22 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    OP, what wheels and tires are you trying to run? Did you go with factory offset or something different?
  4. Dec 10, 2014 at 6:36 PM
    Clange1731
    Hayesville,nc
    03 prerunner trd
    I get my alignment done tomorrow we will see if it helps. I am trying to run rockstar 775's with 33x12.50 the place I got them from though he had the correct offset I needed
  5. Dec 10, 2014 at 6:37 PM
    Clange1731
    Hayesville,nc
    03 prerunner trd
    I am looking to get new uca's but they are so dang expensive
  6. Dec 10, 2014 at 6:43 PM
    604YOTA
    604YOTA Well-Known Member
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Grey wire mod, eibach, 5100's & 5125's, ome Dakar leafs, 1.25 rear shackle, Gibson exhaust, ram air intake, throttle body spacer, boot slide mod, poly bushing kit, extended brake lines.
    Problem is the back spacing on those rims not your uca. What back spacing do they have?
  7. Dec 11, 2014 at 5:53 AM
    offrdmania
    Templeton, Ca
    You need to wait until its aligned to verify offset/backspacing. Its all jacked up right now because of the camber and toe being off
  8. Dec 11, 2014 at 9:12 AM
    Clange1731
    Hayesville,nc
    03 prerunner trd
    The guy at the wheel place said my back space he sent was 4.89
  9. Dec 11, 2014 at 12:04 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Camburg uniball UCA from Wheelers = Done
  10. Dec 11, 2014 at 12:10 PM
    cgs2k2
    cgs2k2 old man
    get some wheel spacers
  11. Dec 11, 2014 at 12:14 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    you need 4.5 or less backspacing
  12. Dec 11, 2014 at 12:14 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    This thread lacks info. Backspace means nothing without knowing the wheel size.
  13. Dec 11, 2014 at 12:16 PM
    bellassaiw10
    Currituck NC
    Unless he's rocking boggers its really not going to make that big of a difference
  14. Dec 11, 2014 at 1:30 PM
    dexterdog
    Oly WA
    2012 F150
    He's trying to mount Rockstars. That should tell you it's possible.
  15. Dec 11, 2014 at 2:24 PM
    bellassaiw10
    Currituck NC
    Hahahaha
  16. Dec 11, 2014 at 3:17 PM
    Clange1731
    Hayesville,nc
    03 prerunner trd
    They are 17x8 with 33x12.50
  17. Dec 11, 2014 at 3:24 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Lol no.
    I'm gonna go ahead and jump to conclusions and say this is not the case. Again, when you install a lift in the front anything past usually 2-3 inches will start to interfere with the OEM dimensions. First, get an alignment if you haven't already. You won't get it within spec without new UCAs.
  18. Dec 11, 2014 at 3:28 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Send the rockstars back and get a cool wheel.
  19. Dec 11, 2014 at 3:29 PM
    TashcomerTexas
    That too^ you probably lost about 5-10 hp
  20. Dec 11, 2014 at 3:40 PM
    Clange1731
    Hayesville,nc
    03 prerunner trd
    I didn't ask for stupid remarks I got what I liked just wanted some help. Can't get help from childish people.
