AGM battery options?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FloTaco, Jun 16, 2019.
  1. Jun 16, 2019 at 4:35 PM
    FloTaco
    FloTaco [OP] Well-Known Member
    Bay Area, CA
    2021 SR DC 4X4
    Hey all, what are you guys running for 27F AGM batteries?
    ColoradoTJ likes this.
  2. Jun 16, 2019 at 4:45 PM
    1moonshine2
    1moonshine2 Well-Known Member
    Appalachian Mountains in VA
    Tacoma 4x4, 4cyl, 5spd, reg cab
    I would stay away from those batteries. They are not worth the money. I would buy a good conventional battery, that's what I'm going to do this fall. My battery is 8 years old, and was weak at times last winter. I checked prices, and there is no way I'm paying more than double for an AGM. I had an Optima battery one time years ago, and that one didn't last long at all before it failed. it would just go dead while the truck sat for a week or so. The battery I replaced it with didn't do that, so I know the problem was with that battery, and not the truck.
    Tacorific likes this.
  3. Jun 16, 2019 at 5:07 PM
    Muddinfun
    Muddinfun Well-Known Member
  4. Jun 16, 2019 at 5:18 PM
    FloTaco
    Bay Area, CA
    2021 SR DC 4X4
    I was considering the X2 as well.
    @1moonshine2, the reason for using AGM batteries primarily involves off-roading and overlanding. They handle vibrations, constant movement, and extreme angles and conditions far better than a conventional battery. It’s well known Optima are no longer good options. A solid AGM is most definitely worth the money when you are off grid.
  5. Jun 16, 2019 at 5:23 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    That's not good advice depending on what he's doing. I upgraded to a Bosch 94R AGM with 80AH to run my fridge. You cannot drain a conventional battery and recharge it back to life like you can an AGM. Now, I work for an auto parts company and received a hefty discount which is nice, but the Bosch was still priced well v. others. There's pics in the link below if you want to see how it fits.
    jcott329 likes this.
  6. Jun 16, 2019 at 5:27 PM
    1moonshine2
    The original post didn't mention any special uses. I thought some people just want one because they want one. I still wouldn't buy one for my use, way too expensive. If you have a use for one, then have at it.
    TacomaMike37 likes this.
  7. Jun 16, 2019 at 5:29 PM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    I've heard good things about Northstar, which is what the X2 that @Muddinfun linked actually is. Never tried one myself, but I'll be considering one whenever the battery that came in my truck kicks the bucket.
    I will say I've had poor experiences with both Optima and Odyssey batteries. First Optima was a pre-Johnson Controls that was an absolute beast. Starting with a friend of mine dropping a crescent wrench across the terminals while I was installing it cuz he thought it was hilarious (nothing caught on fire, so I suppose in hindsight it was) and ended up with someone stealing it, still working, out of the demo derby car me and the same friend ran, 8 years later. But my 2nd, post-JCI Optima, was cranking slow after 2 years in my lowly old Civic. I totalled the car before it actually died, but with how it was working by then, and how many more I've seen die in 18-24 months, I'm not paying the premium they bring.
    A total of 4 Odysseys from when they were sold as Diehard Platinum got replaced between my old Tacoma and my old Subaru. The original and 2 replacements in the truck all went at 1-year intervals, and the one in the car died at 2 years IIRC. For what I paid I'm glad I got them from Sears and before Sears disappeared, cuz I would've been pissed to not have easy warranty replacement for them.
    If you decide to go with a Northstar I'd recommend buying it from Batteries+ for the same reason, unless you have some other local source. They do give a rather generous warranty period, and a pretty wide presence if you need to warranty it.
    Honestly though, unless you're doing a lot of wheeling that might beat a lead-acid to death, I'm not sure that AGM is worth it. I've been a proponent of them for years. Other than my old Optima, the only ones I haven't had an issue from were 2 Deka/East Penns- one the warranty replacement for the Odyssey in my old Subaru after Sears stopped rebranding them, and the Napa one I put in my old Tacoma once the last warranty Odyssey went up. But I didn't have either of them all that long to say they lasted longer than a flooded battery.
    Muddinfun and FloTaco[OP] like this.
  8. Jun 16, 2019 at 6:51 PM
    dofartshavelumps
    dofartshavelumps Well-Known Member
    NH
    2015 SR DCSB 4x4 4.0 MT
    X2 or Northstar. How much is a tow/jump when you are stranded? Made in USA, at least it was when I got mine a few months ago.
  9. Jun 17, 2019 at 1:32 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    I live in FL and heat kills regular batteries within 3 years - they last a lot longer in cooler/cold climates so I bought the Advance AGM Battery size 24F - 710CCA $158. (3 year warranty) from Advance Auto. After 4 years it was still in perfect condition but put a new one in anyway as I tow my boat and with the ramps do not ever want a dead battery! Old one is my backup one now for longer off road trips.
    As a note if you order online usually a 20% or 25% discount. So really about $50 more than a regular wet acid battery - up to you.
    bishtaco and Rambo54 like this.
  10. Jun 17, 2019 at 2:04 AM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Good choice @Muddinfun.
    I have the X2 in my rock crawler. Great battery's to buy. Always buy online with the discount. Saves you a few cases of beer money (good beer).
    My one and only yellow top Optima lasted a year.
    I use my winch a lot to roll people back over (surprisingly a lot this past year pulling my stuck Subaru Crosstrek with snow tires out of my snowy driveway). I run a Taurus 3.8L two speed electric fan that can draw up to 100 amps on startup, and a transmission cooler fan. Pretty much stress my electrical system to the max. This battery has never let me down.
    When my Duramax needs batteries, the X2 is on the top of my list.
    Muddinfun[QUOTED] likes this.
  11. Jun 17, 2019 at 3:29 AM
    grant318is
    grant318is Well-Known Member
    Connor
    Lovettsville, VA
    07 Tundra RCSB
    I also have an X2 power and love it. Had a odyssey 24f in my 5th gen, but the 27 has a good amount more AH. I have been able to power my Dometic CFX50 for 3+ days off of it with only small bits of trail driving mixed in. I also like that I can warranty it out if needed at any batteries plus that has it in stock.
  12. Jun 17, 2019 at 7:29 AM
    FloTaco
    Bay Area, CA
    2021 SR DC 4X4
    Looking at the Bosch AGM 24 series online, $170. It’s made by Exide, not sure of the quality.
    My current Duralast crap will live in a battery box in the bed to power accessories, tended by a solar panel on the trail.
  13. Jun 17, 2019 at 7:48 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    NSB-AGM27F. FWIW, there are periodic Group Buys for these. (Unfortunately, the most recent one just ended, so it'll probably be several months before the next.)
    Don't forget a Voltage Booster to properly charge your AGM battery.
    BassAckwards and crashnburn80 like this.
  14. Jun 17, 2019 at 8:02 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    I just replaced my battery yesterday with a Everstart 24f from Walmart. It was $95. I have no clue why people spend upwards of $300 for a battery. I guess its the same crowd that buys YETI coolers.
  15. Jun 17, 2019 at 8:19 AM
    FloTaco
    Bay Area, CA
    2021 SR DC 4X4
    TacomaMike37, for the reasons stated above, folks go with an AGM when traveling to remote areas, extreme conditions, and heavy draws. For normal road use there is no point, but we’re talking about a totally different use of the vehicle.
  16. Jun 17, 2019 at 12:52 PM
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    I have the X2 from batteries plus as well. I can tailgate all day and run 2 tv's and a small fridge, a large speaker and an electric grill through an inverter with the engine off for 8 hours while throwing back roughly a billion coors lights with the boys and the engine turned over no problem.
    Muddinfun likes this.
  17. Dec 13, 2020 at 8:05 AM
    Spuds
    Spuds Well-Known Member
    Dave
    2020 Tacoma SR5 4x4
    All LED lighting, K&N filter w/TRD air accelerator, black and tangerine Katzkin leather seats, JL audio Components, rubber floor liners, de-badged, (next mod: orange powered coated winter rims & JL stealthbox)
    You used a boat battery? Direct swap, or did you add this and now running two?
