AGM Battery Upgrade.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Espo1961, Jun 24, 2023.
  1. Jun 25, 2023 at 4:48 AM
    BillyE
    BillyE Well-Known Member
    For me, the only reason to change is to avoid corrosion from battery acid venting. And that’s a significant issue in hot weather. I’m planning on making the change.
    Espo1961[OP] likes this.
  2. Jun 25, 2023 at 4:56 AM
    Espo1961
    Espo1961 [OP] Member
    2017 Tacoma TRD 4X4 Access Cab
    Stock
    Agreed. I’m also having that same problem.
  3. Jun 25, 2023 at 5:02 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    There is enough anecdotal evidence out there that says you can swap over to an AGM battery and do nothing else and you will be just fine. The tune guys saw a marketing opportunity here and wave the "you gotta get a tune for it to work" whenever someone asks about these batteries. From a business perspective, I don't blame them as it sells tunes!
    Rusty66, ricco333 and Espo1961[OP] like this.
  4. Jun 25, 2023 at 7:35 AM
    Espo1961
    Stock
    I can understand that but I also have acid that constantly is all over the battery top and brackets and the AGM does last a lot longer than the OEM battery. I’ve replaced 2 so far and they always seem to give up at the worst time.
  5. Jun 25, 2023 at 9:38 AM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    So who makes a good AGM? Is the Wally World AGM made by a reliable supplier or do I need an X2Power?
    Espo1961[OP] and MGMDesertTaco like this.
  6. Jun 25, 2023 at 9:50 AM
    MGMDesertTaco
    Wally Worlds Everstart AGM is made by Johnson Controls; basically the same agm that Costco sells, but it's got a 4 year free replacement warranty and only costs about $170. It was the cheapest 24f agm with the best warranty I could find. So far (1.5 years) has worked well with many aftermarket accessories (stereo, amps, lights, arb twin). It's also only about 4lbs heavier than stock and still fits in the oem plastic tray.
    I'm using an offgridengineering strap to hold it in place.
    Northstar X2 and Odyssey make quality AGM's, but they cost twice the price.
  7. Jun 25, 2023 at 11:27 AM
    Espo1961
    Stock
    Great info there MGMDesertTaco!
    Now I know where I’ll be going for the AGM battery once I get the flash done!
    MGMDesertTaco likes this.
  8. Jun 25, 2023 at 11:36 AM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    AGM is fine stock, been doing it for a long time. Worst I've had is 6 years, best has been 9 years.
    The 9 year old was a Mexico yellow top. Still had decent CA but I was getting nervous for the upcoming winter and the casing had cracks around the terminals.
    +1 for Walmart / Costco 24F AGM, can be hard to find though.
  9. Jun 25, 2023 at 11:57 AM
    BillyE
    Get a battery with a good warranty at a place that will have it in stock when you need it.
  10. Jun 27, 2023 at 8:40 AM
    urbanrails
    urbanrails Well-Known Member
    Long Island, NY
    2018 TRD OFF ROAD
    Just replaced my stock (made it 5 years) battery with a 24F AGM from Costco. I don't know if it's in my head or the old battery was just that shot, but the truck definitely starts up easier and idles better. Was getting some bad voltage surges it seemed like at idle and its gone and smooth now. I'm gonna take my chances on running this as is with no tune, seems enough guys do it.
  11. Jun 27, 2023 at 8:44 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I think with no tune is mostly fine. Old Jeeps run AGMs quite popularly and they have nothing but a simple voltage regulator in the PCM that keeps the charge somewhere between 13.2-14.2. AGMs can last up to 10 years in those, so I bet it’ll be fine on the Tacoma too with a very similar charge profile. A tune would actually concern me about overcharging.
  12. Jun 27, 2023 at 11:32 AM
    Citizen Rob
    Citizen Rob Well-Known Member
    Sacramento, CA
    2016 Tacoma TRD OR DCSB 4x4
    I've got an optima yellow top that's been charging in my truck at 14.9v for at least a few hours a day for the last 4 years. Never have had a power problem.
