AGM or not AGM
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jazz1one, Jan 25, 2020.
  1. Jan 28, 2020 at 4:08 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    This is a good definition from Wiki:
    The most common function of a diode is to allow an electric current to pass in one direction (called the diode's forward direction), while blocking it in the opposite direction (the reverse direction). As such, the diode can be viewed as an electronic version of a check valve. This unidirectional behavior is called rectification, and is used to convert alternating current (ac) to direct current (dc).
    Automobile alternators have diodes to block part of the waveform, so produces DC power like a generator.
    EdinCincinnati likes this.
  2. Jan 28, 2020 at 9:06 AM
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    https://www.tacomaworld.com/threads...r-voltage-booster.611314/page-2#post-22242767
    Check out this thread. You can get a diode from Ford for about $13.xx I did it to mine a little while ago and it seems to help. Goes from 14.2v to 14.7v output. I have the X2 battery and had it for about 2 years before adding this diode and never had an issue. But having the peace of mind is nice. Plus added voltage output will increase the output of your headlights assuming you have halogen lamps.
  3. Jan 28, 2020 at 9:13 AM
    Syncros
    Syncros Well-Known Member
    Have had a rebranded Exide Edge in my truck for 4+ years. No charging system mods, it's going strong. I do have a Noco Genius g3500 charger that I run on it once a month or so but I treat my lead acid batteries the same.
  4. Jan 28, 2020 at 2:27 PM
    ucdbiendog
    ucdbiendog Well-Known Member
    Reno, NV
    2014 DCSB TRD OR
    Bilstein 6112 + 5160 + Dakar MD, Stubbs HD-SKO sliders, BAMF skids, BAMF front bumper, Relentless Rear
    great, add this to the list of stuff to do. Looks like the previous owner of my truck put in an AGM battery, but no voltage boost.
