AGM solar charger on starting battery
Discussion in 'Technical Chat' started by soggyBottom, Jul 15, 2024.
  1. Jul 15, 2024 at 5:01 AM
    soggyBottom
    soggyBottom [OP] Well-Known Member
    I have 1 battery on my 3rd gen its an AGM. I'm interested in adding a small solar panel.
    How do I hook up a charger on the same circuit as my alternator? Are there any solar chargers that are smart enough to be on the same circuit?
  2. Jul 15, 2024 at 1:42 PM
    Blueberry.Taco
    Blueberry.Taco blueberry.taco (IG)
    Ryo
    Fulltime Overlanding
    Long travel house on 35s with a custom aluminum utility bed and FWC
    some welding required
    typically a solar charge controller goes between the panel and the battery. alternator doesn't care
    soggyBottom[OP] likes this.
  3. Jul 15, 2024 at 5:36 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    Agreed, most any solar controller should be fine. If the alternator carries the voltage higher than what the solar controller is set for, the solar controller simply suspends charging until the voltage drops back down again, and vice-versa.
    I have a Morningstar SunSaver unit.
  4. Jul 15, 2024 at 6:07 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    My controller has a 12v switched input. Once the ignition is on, the solar is de-activated. Solar is fed directly to battery. No need to mess with your alternator.
  5. Jul 16, 2024 at 6:01 AM
    soggyBottom
    What controller? Or are you just using a relay or something?
  6. Jul 16, 2024 at 7:40 AM
    OldSchlPunk
    Rich
    East Central Wisco
