AGM Worth the extra $50?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Avanchent, Jul 18, 2021.
  1. Jul 18, 2021 at 3:47 PM
    Avanchent
    Avanchent [OP] Well-Known Member
    Longmont CO
    2017 TRD Sport MGM DCSB
    Well the battery in my other car died today, it was a Napa battery from 2017. I'm thinking about replacing the one in my Taco as well as it's on the original from 2017 and they both use the same battery, would you guys say it's worth the extra $50 to go with an AGM battery? Both Costco and Walmart have a $50 difference in price and I've always had good luck with their batteries (5+ years) but never bought AGM.
  2. Jul 18, 2021 at 3:58 PM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    The Walmart AGM for $150. is a good battery. I've had mine in my 2020 for 20 months with zero issues.
    FYI, I have not used a wet acid battery for over 25 years. IMO, they SUCK!
  3. Jul 18, 2021 at 4:11 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    Just keep in mind that AGM prefer to be charged between 14.4 and 14.8v, your alternator charges to 13.9. Not sure how to get around that on a third gen besides putting it on a charger once a month or so. I'm running one and added a solar panel to help with keeping it topped off
    stacksmasher and eurowner like this.
  4. Jul 18, 2021 at 4:12 PM
    Shellshock
    Iowa
    You can modify the alternator voltage with vF tuner in 2016+
    shakerhood, jmneill, su.b.rat and 5 others like this.
  5. Jul 18, 2021 at 4:26 PM
    SRBenjamin
    Benny
    Don't listen to this charging conspiracy group. I've run my AGM in my stock 2020 for over 20 months, and it always reads 12.9~13.1 volts after the engine is shut down.
    Any voltage over 12.8 is a full charge on an AGM. If running an AGM on a Tacoma stock system was a problem, I would have seen some issue with my AGM.
    stacksmasher likes this.
  6. Jul 18, 2021 at 4:38 PM
    Wyckedan
    Dan
    Woodinville WA
    The only problem you'll notice is when you replace it in another year or so instead of 3 more years
  7. Jul 18, 2021 at 4:43 PM
    SRBenjamin
    Benny
    Keep repeating the lie, someone will believe you, just not me. See I've actually tried this AGM, and it works fine. You have not, you are just being a forum Parret.
  8. Jul 18, 2021 at 4:57 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Two tangible benefits I see with AGM:
    The flooded batteries have vent holes which can leak acid off-road on steep inclines or off-camber.
    The higher cranking amp rating of AGM means you can go with a smaller battery. I'm running an Optima Red 35 which is 20 lbs lighter than the OEM 24F.
    Mas Olas and shakerhood like this.
  9. Jul 18, 2021 at 5:02 PM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    Lasted 4 years. Why change and pay extra?
    pretty normal lifespan.
    Lt. Dangle likes this.
  10. Jul 18, 2021 at 5:03 PM
    Rockefelluh
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    Literally no one who crawls on this forum has incline issue with lead acid batteries.
  11. Jul 18, 2021 at 5:06 PM
    Wyckedan
    Dan
    Woodinville WA
    It's spelled Parrot. And it's not a lie. It's a fact they prefer to be charged higher to maximize lifespan. If you want to call me names over something as trivial as a battery, you can go fuck yourself
    https://www.tacomaworld.com/threads/the-northstar-agm-battery-voltage-booster-upgrade.604478/
    RX1cobra, Chaosh1, E.J. and 8 others like this.
  12. Jul 18, 2021 at 5:07 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    I've observed acid trickling out of the vent holes just transporting batteries in my car's footwell. It does dry out fairly quick so you won't notice it under the hood except for additional rust on the battery mount platform. I suspect it's the reason Toyota put the white plastic tray under the battery.
    jmneill likes this.
  13. Jul 18, 2021 at 5:11 PM
    su.b.rat
    su.b.rat broken truck
    :rofl: :burp:
  14. Jul 18, 2021 at 5:23 PM
    woodsy
    woodsy Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    And yet another thread turns into a pissing match lol.
    gsubioguy likes this.
  15. Jul 18, 2021 at 5:35 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    My ran an Optima Red Top for 5 years in two trucks at stock charging voltage with no issues. After 5 years it was still working fine but I preemptively replaced it with another Red Top. My understanding is the lower charging voltage just reduces the available battery capacity, e.g. it'll power a fridge for only 3 days instead of 4 days, etc.
    For 3rd gens (especially 2016-2019 models) a tune is highly recommended, so it'll be a good opportunity to flash the ECM to the AGM charging voltage, but it's by no means a necessity. If a flooded battery is installed in the future, the ECM would need to be reflashed to the stock voltage to avoid damaging the battery.
  16. Jul 18, 2021 at 5:39 PM
    Shellshock
    Iowa
    ^this
    You just get more usable power. It may last slightly longer but not enough I’d consider it significant
    I ran mine for over a year before voltage modifications were even possible
    su.b.rat likes this.
  17. Jul 18, 2021 at 5:40 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    ^100%
    Lead acid batteries have been leaking all over shit for 150 years.
    And when they're not leaking, they're busy off gassing Hydrogen to slowly oxidize anything in the immediate vicinity.
    My last Optima lasted 10 years. I'm on year #9 with a Red Top in the family car and have a nearly new 3 year old one in the Tacoma.
    Got over 8 years out of whatever AGM Kubota put in my last ZTR mower without even putting it on a tender during the winter months.
    In my ever growing experience with AGM batteries, I've more than made my money back in longevity and lack of one type of maintenance or another.
    Now then again, every generation before us successfully endured lead acid batteries, so there's that. :D
  18. Jul 18, 2021 at 5:41 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    He's a dick who knows everything and has never been wrong before.
    Except for spelling, or how agm batteries work I guess. Other than that, he's never been wrong before.
    oneinthestink, cemented, E.J. and 3 others like this.
  19. Jul 18, 2021 at 5:44 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    ...or just stay with a flooded cell and avoid the extra bullshit and save $50.
    Seems like a big hassle for such little gain.
    I'm fine with Walmart flooded cell batteries.
    BuddyS and Lt. Dangle like this.
  20. Jul 18, 2021 at 5:55 PM
    jmneill
    SE
    On another note, Lt. Dangle, you're responsible for me wasting a lot of time watching old Reno911 clips on YT, that I would have otherwise forever forgotten. :rofl:
    Humor that has forever been taken from us.
