ah more lift questions
Discussion in 'Suspension' started by l_prettyman, May 11, 2010.
  1. May 11, 2010 at 10:22 AM
    l_prettyman
    l_prettyman [OP] Well-Known Member
    Logan
    Easton Shore Maryland
    06 4x4 SR5
    12% tint, Leer cap, Pioneer Avh3100DVD headunit, Kinetik 2000 battery, Memphis pr1.1000 amp, Pioneer subwoofer(not sure what kind), Back-up Camera, PA/CB system
  2. May 11, 2010 at 10:31 AM
    whitebread
    whitebread Well-Known Member
    Raleigh, NC
    2011 4x4 DCSB TRD Off-Road
    Leer 100XL and a bunch of off-roading scars.
    As you say it is better than a spacer kit, but I would be concerned with the stock damper travel when combined with those springs. It might be just as cost effective to do 5100s in the front at 2-1/2" with your stock springs, then use an AAL and their extended travel kit on your existing rear dampers.
  3. May 11, 2010 at 10:35 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I have that exact lift with the 885's and the rear AAL. So far no issues on my truck but then again, I swapped out all my stock TRD shocks with Billy 5100's. Rides a bit stiffer but I dont mind that.
  4. May 11, 2010 at 11:28 AM
    l_prettyman
    Logan
    06 4x4 SR5
    so im guessing i can ride with these with stock springs until i can get billy 5100's?
  5. May 11, 2010 at 11:33 AM
    l_prettyman
    Logan
    06 4x4 SR5
    do those shock extenders work with the front shocks also or just the rear?
  6. May 11, 2010 at 11:58 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    It should be okay for a little while but I'm not positive. Technically the OME coils are supposed to be best with the OME shocks. The OME-90000 are for the front and the OME-N182's are for the rear. I just went with the 5100's cause they were cheaper in price. I dont regret going with the 5100's even till this day.;) You can look at it all on Toytecs website.:cool:
  7. May 12, 2010 at 3:19 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    just the rear
  8. May 12, 2010 at 3:23 PM
    whitebread
    Raleigh, NC
    The travel up front will come from the 5100s.
