Ahhh! Damn dealer!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoskim, Jul 30, 2008.
  1. Jul 30, 2008 at 1:00 PM
    tacoskim
    tacoskim [OP] Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    k so im frustrated.... they found nothing wrong with the vibration. so now i asked them bout the Limited Slip Differential, if they used the proper additive since its a LSD. he said he has to check now on that when i first asked him that the first time i took the truck in. so now my question is can it be possible that they put in the wrong LSD oil and is causing vibration on the steering wheel while turning left from a stop??? would the service guy have the info on the invoice if they used the right oil??
  2. Jul 30, 2008 at 1:09 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Invoices aren't always the truth.
    From what I understand about the LSD, if you use the standard fluids back there, then your clutch will wear out and the LSD will act open. I don't know if it would cause vibrations along the way.
  3. Jul 30, 2008 at 1:15 PM
    tacoskim
    Los Angeles, CA
    Stock
    can it be possible that the gears are getting use to the new additive and causing it to vibrate. all the symptoms right now to me seem like it can be a LSD problem... during the 30,000 service their supposed to change the LSD fluid, i wonder if they put the wrong oil in?
  4. Jul 30, 2008 at 1:32 PM
    tacoskim
    Los Angeles, CA
    Stock
    anyone experience problems with their LSD??????
  5. Jul 30, 2008 at 1:51 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    its very possible that they put the wrong gear oil in there. when you use the wrong stuff on a lsd, it will wanna seem to grab real hard or the clutches will chatter like a sumbitch till you get the right stuff back in there.
  6. Jul 30, 2008 at 1:55 PM
    tacoskim
    Los Angeles, CA
    Stock
    thanks for the reply.... k so its been almost 2 weeks since i got the service done, how much pressure and how bad is it for my LSD to be running with the wrong oil right now. ive driven atleast 300 miles since i got the service done, am i literally fucking up my LSD right now??? i ask cuz i dont have another appointment till monday
  7. Jul 30, 2008 at 1:56 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    man, i'd go get 3 quarts of some gear oil and some lsd friction modifier and swap it out myself if i were you!! it probably hasnt really done any damage to them per say, but it sure aint good for it.
  8. Jul 30, 2008 at 1:58 PM
    tacoskim
    Los Angeles, CA
    Stock
    yea but they were supposed to do this during the 30,000 service so it should be warrantied by toyota. if they did use the wrong oil then maybe i can be legible for a whole new LSD??? i would do it my self but i heard changing the LSD fluid can be hard to do right
  9. Jul 30, 2008 at 2:01 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    nah man, easy as pie!!!
    drain the oil out, put fill plug back in.......use the portion of the bottle that needs to be used of the friction modifier, and add gear oil till it starts coming out the top.........then put the cap on and drive it around for a few minutes, then just do a quick recheck when you get back. we'll walk ya thru it if you wanna do it brotha!!:)
  10. Jul 30, 2008 at 2:10 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    don't do it. This is a warranty issue. If you touch it, then you no proof that they screwed you. I would demand a new clutch pack from them.
  11. Jul 30, 2008 at 2:12 PM
    tacoskim
    Los Angeles, CA
    Stock
    yea thats what i was thinking, since they might of fucked up its their issue. u really think i can get a new clutch pack out of this??
  12. Jul 30, 2008 at 2:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    im gonna almost guarantee you they will not put a new clutch pack in there for ya!! all they will do is drain/fill with the correct fluid, and its still not gonna be synthetic either. thats the way dealers are......they go the cheapest route...........and its why i'd do it myself!!
  13. Jul 30, 2008 at 2:19 PM
    tacoskim
    Los Angeles, CA
    Stock
    well hopefully since ive been going to the same guy for over a couple years he might be cool and hook me up... if not then im gonna take it to the top, cuz not putting in the right oil is unacceptable, esp when ur payin alot of money on that major service!
  14. Jul 30, 2008 at 2:20 PM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    that sucks man, go to another dealership and get a second opinion....
  15. Jul 30, 2008 at 2:21 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i agree!! in my experience with dealers though, they'll tell you it wasnt a certain thing, like the lsd, that was wrong, when in fact it was, just so they dont look bad. hopefully, you get you truck straight though. i'd still do a drain/fill with the right stuff and friction mod. and see if that does it though, but thats just me!:)
  16. Jul 30, 2008 at 2:28 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    if this is the case, you have already done irreparable damage to the clutch pack. I don't think a replacement is out of the question.
  17. Jul 30, 2008 at 2:33 PM
    tacoskim
    Los Angeles, CA
    Stock
    so if this is the case am i really messing up the LSD right now with driving?? my appointment isnt till monday, should i hold off driving my truck??? i gotta go to work
  18. Jul 30, 2008 at 3:19 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if you can find another means of transportation....i would. or you can drive it and let the dealership foot the bill for messing up in the first place.
  19. Jul 30, 2008 at 3:35 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I say keep using it, and then make them fix it.
  20. Jul 30, 2008 at 3:50 PM
    wushaw
    wushaw Well-Known Member
    Texas
    08 AC TRD 4x4 6sp
    If your clutch pack is toast there is no reson not to drive it, warranty should take care of it.
    I don't know what Toyota calls out for their LSD but on my Jeep with the OEM track lock it is standard 70-90wt with their little bottle of friction modifier, supposedly synthetic fluid is too slippery for the clutch packs to operate correctly.
