ahhhhhh 4X2
Discussion in '2nd Gen. Tacomas (2005-2015)' started by snjkid372, Mar 1, 2009.
  1. Mar 2, 2009 at 8:01 AM
    #41
    Front sight
    Front sight Well-Known Member
    SW Florida
    06 Prerunner TRD Sport
    Full OME 3"lift, LR UCA's,Destination 285/70/17's, 1.25 spidertrax, K&N drop in, 2nd filter removed, Weathertech liners, Toyota bed mat, reverse lights,Wet Oklee's, bedlights and other small stuff.
    I really have no need for 4wd. I don't go muddin, no snow or ice. The boat ramps that I use are not an issue either. 4WD is great for getting you moving from a stop, but one your moving it's mostly about the driving technique.
  2. Mar 2, 2009 at 8:53 AM
    #42
    ERdept
    ERdept Well-Known Member
    Questions:
    1. Will a 2WD WITH the locker help and be better?
    2. Will deflating tires to get more area, like when off-roading help?
    3. Will doing both of the above, and momentum, get you out and moving in the OP's situation?
  3. Mar 2, 2009 at 9:36 AM
    #43
    wawireguy
    wawireguy Well-Known Member
    Lockers would help get moving but you wouldn't want it for hwy driving. Putting weight in the back will help immensely. You can make durable sandbags from rubber inner tubes. Cut them in half. Rivet the ends closed with washers. I'd get a set of cable chains and carry a snow shovel in the back. Person with that setup will be fine with a little common sense.
  4. Mar 2, 2009 at 10:04 AM
    #44
    betz.steven
    betz.steven Well-Known Member
    Southern NJ
    2011 TE 4Runner
    Im in NJ today with the same snow "Storm" in my pre-runner, so far so good. i agree with the post whore as well, its all about how you drive it. i even had to pull my neighbors 4X4 suburban out of her driveway. on a side note the BFG MT KM2's handle suprisingly well in the snow.
  5. Mar 2, 2009 at 10:16 AM
    #45
    snjkid372
    snjkid372 [OP] Well-Known Member
    Atlantic City
    08 DC Prerunner
    yea im riding with those stockers that came with the 16inch steelies....but i did just pack the shit out of my bed with snow i hope that helps a little...
  6. Mar 2, 2009 at 10:19 AM
    #46
    betz.steven
    Southern NJ
    2011 TE 4Runner
    Yeah, the stockers suck, i had a few close calls of getting stuck in places i should have had no issue with and havent since i changed the tires. for the snow in the bed, i did the same thing this morning :D
  7. Mar 2, 2009 at 10:28 AM
    #47
    snjkid372
    Atlantic City
    08 DC Prerunner
    well i just bought the 17inch trd sport wheels, i'm going to get them powdercoated black and throw either some bfgoodrich a/ts or nitto terra grapplers, so hopefully my traction will be a lot better
  8. Mar 2, 2009 at 10:31 AM
    #48
    betz.steven
    Southern NJ
    2011 TE 4Runner
    should improve it by leaps and bounds. i'm partial to the BFG's (looks) but have seen nothing but good things about the grapplers
  9. Mar 2, 2009 at 10:35 AM
    #49
    snjkid372
    Atlantic City
    08 DC Prerunner
    yea. i want some mud tires but they just aren't meant for my type of driving (which is on mainly on the highway)
  10. Mar 2, 2009 at 12:28 PM
    #50
    Okkine
    Okkine Well-Known Member
    Alberta
    1998 Tacoma, V6, Manual Transmission, 4x4
    Three things you need to do. First, quit listening to everyone who tells you you need a 4x4, because you don't. It's a nice luxury, but proper winter driving techniques are far more important than four wheel drive. Second, Put some weight in the bed (150-250 pounds). That will help you get better traction in the snow. Third, get a good set of winter tires, they make a big difference. I learned to drive in my Dads rear wheel drive trucks (I've never even driven a 4x4) in southern Alberta, and have never had need for 4wd (It would be nice at times, but not necessary). I took my new Tacoma to Calgary for Christmas where it snowed the whole two weeks. I had no problem whatsoever in the snow or ice, even made it up my Grandfathers steep, icy driveway. This truck handles beautifully in winter conditions, if you drive them properly. Good Luck :thumbsup:
  11. Mar 2, 2009 at 12:35 PM
    #51
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    You don't need 4x4 except for certain circumstances. However to not be a road hazard and go 20kms around corners you need 4x4. Had a few instances up north in Fort Mac where anything but idle up this one hill would produce fishtail. Even gentle acceleration would cause it to slide. Not with 4x4 though. It's not just because the front wheels are pulling but because the torque is cut in half to the rear tires.
