Aiming 3rd gen headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Citadel, Dec 30, 2016.
  1. Apr 7, 2018 at 2:37 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Oh, be careful, the high beams go with them. They're on the same screw, not separate.
    Tacoma_Runner1129 likes this.
  2. Apr 7, 2018 at 4:16 PM
    cak
    cak Well-Known Member
    Palo Alto, CA
    2017 V6 4x4 SR5 ACLB
    RobP62 likes this.
  3. Nov 29, 2018 at 2:40 PM
    Marbleyard
    Marbleyard Thread killer
    Virginia
    2019 4Runner Pro
    SOLD 2016 taco: premium technology and tow package. OV Tune 1.05; A.R.E. V Camper Shell; BRO grille & Tails; OEM bed mat; Xenon Depot HID headlight conversion; reflective gray tailgate letter inserts; GoPro session; Hondo radio knobs; K&N cold air intake, quicksand painted dash bezels, Subaru dash speakers, Kicker CS 6x9 fronts and 6.5 rear speakers; All LED interior lights and LED high-beam headlights. Redline elite hood shock props. prinsu cab and camper rack with rough country 30" light bar; (2) 8" rear facing “F.U.”rough country black LED lights; prinsu cargo basket kit, (2) prinsu load racks; roadshower 4; ARB 2500 awning and room kit; weather tech floor mats; carhart seat covers; ckma12 ARB air compressor under the hood; blue ridge overland gear air tools bag, tool bag, driver's seat molle. Rack mounted TRED 800 recovery treds and plano case. Rotopax water and fuelpax fuel canisters; Pelican cased first aid kit in bed. rockblokz mud flaps. ARB rear dif. breather. Stand alone fuse block. SSO bumper with 10k smittybilt synthetic line winch and factor55 ultrahook. Pro Eagle 2-Ton “The Beast” jack. OME lift kit: 90000 front shocks and 886 OME coils, Camburg 310078 UCA, 60091 rear shocks with light duty Dakar leafs. Good Year duratracs 285/75R16. Black vinyl inlays on factory OR wheels; RCI Steel Front/Trans/Trans Case/Rear Diff Skids, Alum A-Arm; Mobtown bolt-on sliders with scorpion bed coating; pelfreybilt aluminum fuel tank skid; Cali-Raised full length Molle storage LH & RH bed sides; Caliraised bedside reinforcements; HELLA sharptone horns; Optima blue-top battery with AJT machined red tiedown bracket. AJT quicksand key fob. Overland Bound member #6996
    I’m two evenings into my new HID bulb swap and I’m still getting flashed. I haven’t had a wall to adjust to so I’ve been counting the cog notches as I turn it. First night, 20 ticks, still got flashed. I did another 30 tonight. It’s counterclockwise down correct? For those who have had to make this adjustment how much turning did you do? I don’t expect the same cog notch reply, just did it seem like you had a lot of turning to do? I do have a 2” lift.
  4. Dec 3, 2018 at 6:17 AM
    Marbleyard
    Virginia
    2019 4Runner Pro
    I never got a reply so I managed to figure this out on my own.
    When turning counterclockwise for down, turn the screwdriver counterclockwise, not the cog.
    Cog counterclockwise= beam up
    Cog clockwise= beam up
    This is really for those trying to do this without a wall. After my fails without a wall, I strongly recommend you find one.
    Fast1 likes this.
  5. Dec 27, 2018 at 6:39 AM
    Yota2019
    Yota2019 2019 Limited
    James
    Freeport, FL
    2019 Tacoma Limited 4x4
    O.E. for now.
    Thanks for the 411.
  6. Aug 14, 2019 at 9:49 PM
    '16goingon'17
    '16goingon'17 Well-Known Member
    Trailslayer
    NoVA by way of NWA
    2017 TRDOR 4x4 DCSB MT
    JBA STD UCAs. 6112/5160 @6/5. Wheelers 1.5" 3AAL with Superbumps. BROG molle headrest covers. GMRS & Ham radios with roof-mounted NMO Laird Phantom antenna. Thinkware front/rear dashcams, FreshMexicanTaco's DMM, Meso's dome/map LEDs & Flipfob, Swingcase on driver side. Accumulator Delete Mod (ADM). Two-wheel drive Low Range Mod (2LM). Overland Tailor Tune (OTT) 7.0. Extra juicy oil spill on the bed mat.
    @crashnburn80 the headlight aiming procedure and how-to here would be really helpful for the community to incorporate into your excellent sticky on headlights.
    Chew and crashnburn80 like this.
  7. Aug 14, 2019 at 9:56 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Good idea. I actually have it in some other threads but didn’t include it in the 3rd Gen thread. I’ll be sure to add it there as a helpful resource.
    Skydvrr likes this.
  8. Dec 9, 2019 at 5:20 PM
    silverflash
    silverflash Well-Known Member
    Bill
    Harnett county NC
    2019 TRD 4x4 OFFROAD DCSB Auto Quicksand
    tyger armor side bars tyger tri-fold tonneau cover avs bug deflector II scangauge II
    "When turning counterclockwise for down, turn the screwdriver counterclockwise, not the cog.
    Cog clockwise= beam up"
    so which way raises the beam??
  9. Dec 9, 2019 at 7:10 PM
    Sasquatchian
    Sasquatchian Well-Known Member
    It's actually a federal motor vehicle regulation. No more horizontal adjustments. Not needed with modern lights with a wide dispersal pattern of light. Either BMW or VW were forced into a recall for not capping the horizontal adjustment on their lights.
  10. Aug 18, 2021 at 6:01 AM
    nakedwaterskier
    nakedwaterskier Member
    Jeffrey
    2018 Tacoma TRD
    I pointed up HIGHER my 3rd Gen Taco headlights and upgraded to some cheaper but good and brighter but bad instructions Amazon LEDs. The LEDs are sort of universal and the plugs can snap or lock in even if polarity is reversed--the instructions in the box didn't mention this and they don't work with reversed polarity. THE ADJUSTERS on mine were 8MM bolt heads with geared wheels though you could turn the geared wheels with your fingers also. Easiest to move the windshield wiper solution out of the way; 2 ten mm head bolts or actually screws. HOWEVER, ON MINE CLOCKWISE LOWERED, COUNTER CLOCKWISE RAISED AND IT TOOK MORE TURNS TO MOVE THEM SIGNIFICANTLY THAN OTHER POSTS CLAIMED. i raised the passenger side headlights more than the driver side to not get flashed all the time/to not piss off oncoming traffic. BUT, STOCK LOW BEAMS WERE POINTED TOO LOW AND NOT BRIGHT ENOUGH. My LEDs came with DRIVERS(they are not ballasts) that get HOT so they should be put somewhere away from wires wire looms or engine or exhaust heat or window washer fluid bottle.
    Mt133677 likes this.
  11. Aug 18, 2021 at 6:28 AM
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    You can just use a long philips screwdriver for adjustments. It goes down the channel that leads to the toothed wheel you mentioned, where the end of the screwdriver meshes with the wheel like a set of gears to turn the adjuster. In this case, the screwdriver turns the opposite way the adjuster does, so to turn the adjuster screw counter clockwise, you would rotate the screwdriver clockwise.
    Taco22trdor, musicisevil and Skydvrr like this.
  12. Aug 18, 2021 at 6:39 AM
    nakedwaterskier
    Jeffrey
    2018 Tacoma TRD
    Thanks but was doing it at night so I could see how much up or down they were moving and already done and didn't or couldn't see the phillips option.
  13. Nov 17, 2021 at 8:43 PM
    Mt133677
    Mt133677 Well-Known Member
    SoCal
    2020 DCSB TRD OR
    All the things
    Just adjusted my headlights after the king suspension and deaver pack install. Nose was pointing down a little with some rake due to the deaver pack. Counter clockwise was up for me, clockwise was down.
  14. Dec 15, 2022 at 8:03 PM
    DarinL
    DarinL Well-Known Member
    Darin
    2017 Tacoma 4x4 TRD 4-dr longbox
    SCREWDRIVER, SCREWDRIVER, SCREWDRIVER!!! The entire purpose of those 2 little fins above the cog is to hold the Philips screwdriver in place so you can adjust without ever touching the 8mm or 10mm hex bolt head. This means you don't need to fight with wires and the washer fluid removal like others have posted. With the screwdriver method this entire job will take 2 minutes after you pop your hood 7.6m (25ft) away from a wall.
    Taco22trdor likes this.
  15. Dec 15, 2022 at 8:10 PM
    #35
    818
    818 Well-Known Member
    Gene
    Downey, CA
    2023 TRD Off-Road 4x4
    I’m glad I found this thread. I feel like my lights are a little low. I think it’s time to raise them just a hair.
