Aiming my headlights
Discussion in 'Lighting' started by rmb_crew, May 9, 2010.
  1. May 9, 2010 at 6:45 AM
    rmb_crew
    rmb_crew [OP] My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    For some reason i can get my driver side to line up just fine but my passenger side will not move when i twist the alignment screws. Anyone have any ideas?
  2. May 9, 2010 at 1:16 PM
    rmb_crew
    Anyone?
  3. May 9, 2010 at 1:18 PM
    MJonesTrumpet
    MJonesTrumpet Well-Known Member
    Michael
    Central PA
    I actually have to do this once I get home tonight, after I do, ill let you know how mine turned out. I have the part of the manual downloaded that shows what to turn and what-not. I didnt read it yet, but maybe the passenger side turns the other way? Also, perhaps if it forced it could have been stripped and no longer turns correctly? I dunno, but ill post how mine turns out!
  4. May 9, 2010 at 1:20 PM
    Brunes
    Brunes abides.
    Rotorhead
    How do the bulbs look compared to each other?? Same position in the housing? Is the light all the way seated in the clip??
  5. May 9, 2010 at 1:35 PM
    misterquad
    misterquad Well-Known Member
    (My intentions in my reply is to confess my story of personal stupidity :eek: and is not intended to be taken in anyway against the OP)
    You are driving an 2009 so I doubt the screws are stripped.
    My guess is that you are brighter than me so I doubt my situation applies to you. I was not using the right tool and was not turning the both screws. One headlight went into alignment perfectly and the other took me days to figure out.
    You should have seen the amazement in my eyes when I realized I could use a Phillips screw drivers instead of a small wrench. (Those damn Toyota Engineers are brilliant) Then when I adjusted both screws together to move the headlight. It took me a while to get a clue.
  6. May 9, 2010 at 2:04 PM
    rmb_crew
    Well it might be stripped out. That headlight i bought from someone else i think its off an 07. I might just have to throw my old one back in just so i can aim it.
  7. May 10, 2010 at 6:57 AM
    rmb_crew
    Well got it as close as possible. For some reason the passenger side is different. The top screw moves it up and down and on the Driver its the bottom one. So this whole time i was turning the bottom one and nothing. So its close now. Not perfectly level but its close.
  8. May 11, 2010 at 5:09 AM
    misterquad
    That sounds familiar. I remember just getting one headlight set and just turning both screws to each extreme on the headlight just trying to get it to move somewhere.
    I was so frustrated, they are just headlights, it should have been simple.
  9. May 11, 2010 at 5:35 AM
    JetTech
    JetTech Member
    East Bay, NorCal
    07 TRD Sport D-Cab Long Bed 4X4
    Icon/5100, N-FAB Side steps, AIRAID Intake, Secondary air filter removed, WeatherTech's, OEM roof rack, USA-spec ipod adapter, A/C-defrost mod,2ea Delta bike Hitch Pro2 Locking bike mounts,TRD Skid,Polk 6x9/6,RedLine hood struts,under-hood led lighting...
  10. May 11, 2010 at 11:36 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I think I ran into the same situation on an after-market set that I had. It would not adjust down vertically no matter how much I turned it. It would go up when turned the other direction, but seemed to stop at the same spot moving down.
    I started jacking around with it and ended up turning both adjustment screws up and down, and left to right a few turns, then went back and adjusted downward. It finally went down past the sticking point and I was able to adjust it correctly.
