Air bag light codes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by anthony250f, Mar 21, 2018.
  1. Mar 21, 2018 at 5:44 PM
    anthony250f
    anthony250f [OP] Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    My air bag light came on while off-roading the other day
    It turns off when I start the truck but comes back on a few miles later
    The horn and cruise control work. Also the passenger air bag still works
    Code b2799 (odd that this came up)
    -b1660
    -b1801
    Really hoping it’s NOT clockspring as my truck doesn’t qualify for the tsb
  2. Mar 21, 2018 at 6:35 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Are you using a original key? Or a copy? The b1801 codes is most common to clock cable. And b1660 is common for drivers side seat sensor
  3. Mar 21, 2018 at 6:43 PM
    anthony250f
    Anthony
    San Diego, CA
    No idea it’s the only key I have (used) my uktragauage showed zero codes or pending codes
    Cel wasn’t on
    The scanner said that the b1660 was passenger seat on/off indicator malfunction
  4. Mar 21, 2018 at 8:01 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    Did you check the connection under the seat. When I had the b1801 code it was the clock cable and the 1660 was the switch on the dash
  5. Mar 21, 2018 at 8:02 PM
    anthony250f
    Anthony
    San Diego, CA
    I unplugged all of them and then plugged back in
    How did you fix the dash 1660 code ?
  6. Mar 21, 2018 at 8:05 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    Cleaned the connection and put a dab dielectric grease on it and the that code went away. But the light was still on until I replaced the clock cable. I feel your pain the clock cables are not cheap
  7. Mar 21, 2018 at 8:08 PM
    anthony250f
    Anthony
    San Diego, CA
    I’m probably going to try a aftermarket clock spring. Worth a try at 10$ lol
    desertrunner24 likes this.
  8. Mar 22, 2018 at 9:40 PM
    anthony250f
    Anthony
    San Diego, CA
    Do you really think the clock spring could set off the 1660 code too??
    I checked the connections at the clock
  9. Mar 22, 2018 at 9:45 PM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    I have a bunch of info on the airbag system I can get to it tomorrow.
    I have used the eBay clock springs with luck on two occasions.
    Once - ordered the one without stereo controls.
    Then again with the controls about a year two years later.
    anthony250f[OP] likes this.
  10. Mar 22, 2018 at 10:20 PM
    anthony250f
    Anthony
    San Diego, CA
    I just ordered a cheap eBay clock spring
    I already disabled my wheel controls
    I just find it odd that one code (1801) is def clockspring BUT the 1601 refers to the on off indicator :bananadead:
    When I have a passenger the airbag says on just like it’s suppose to
    Every time I start the truck the light goes OFF but returns very quickly and stays on
  11. Mar 23, 2018 at 7:30 AM
    Radarninja
    Northern California
    06 taco
    image.jpg image.jpg I can’t find 1601. Is it 1610?
    TacomaMike37 likes this.
  12. Mar 23, 2018 at 7:54 AM
    anthony250f
    Anthony
    San Diego, CA
    Awesome!!! Thanks!!
    What is a “center airbag”
    Both codes are related to that
  13. Mar 23, 2018 at 8:15 AM
    Radarninja
    Northern California
    06 taco
    image.jpg image.jpg Center console area
    It’s one of, if not the main computer for the srs
  14. Mar 23, 2018 at 8:19 AM
    anthony250f
    Anthony
    San Diego, CA
    Oh god this sounds expensive as hell
  15. Mar 23, 2018 at 8:20 AM
    Radarninja
    Northern California
    06 taco
    Yeah my truck has a similar issue. I’ve narrowed it down the the driver air bag or that computer.
    And that’s why it’s still not fixed
  16. Mar 25, 2018 at 10:38 AM
    anthony250f
    Anthony
    San Diego, CA
    Well yesterday I drove for two hours on the freeway with no airbag light. As soon as I got off the freeway and started driving on streets the light tuned on
    Makes me think it for sure is the clock spring since freeway doesn’t involve much turning, yet as soon as I turned off the fwy it came on.
  17. Mar 28, 2018 at 6:26 PM
    anthony250f
    Anthony
    San Diego, CA
    Fixed
    Was the clock spring
    Have a annoying clicking sound when turning though
  18. Mar 28, 2018 at 7:03 PM
    Radarninja
    Northern California
    06 taco
    Saweet!... kinda
  19. Mar 15, 2019 at 5:13 PM
    rdsanti89
    rdsanti89 Member
    2003 Silver Tacoma TRD Off Road
    I have a B1100 code. What on page RS-42? I need some info since I thought it was the module. I bought a used one and when I took it to program it they told me the module was fine.
