Air bag light flashing
Discussion in '1st Gen. Tacomas (1995-2004)' started by buzzard1992, Apr 1, 2012.
  1. Apr 1, 2012 at 5:04 PM
    buzzard1992
    buzzard1992 [OP] Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    I have a 01 Tacoma 3.4 4x4 and my airbag light keeps flashing. Every time it comes on though I don't have a chance to go to the dealer. But when I do have a chance it's not on. Any thoughts?
  2. Apr 10, 2012 at 7:08 PM
    buzzard1992
    Alex
    Summerville, SC
  3. Apr 10, 2012 at 7:21 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) 9 Times out of 10, when someone has a flashing airbag light, it is usually the clockwork spring under the steering wheel. It does not matter if it toyota or ford or gm or porsche, the flashing light is a contact problem between the wheel and the clockwork spring. Good Luck.
  4. Apr 10, 2012 at 7:43 PM
    buzzard1992
    Alex
    Summerville, SC
    thanks man. it didnt come on for like 5 days but then randomly today it came on when i was out in the middle of nowhere haha. but then went off after i stopped to get gas
  5. Apr 16, 2012 at 8:20 AM
    Phlip4x4Sport
    Phlip4x4Sport Well-Known Member
    Torrance, CA
    2017 Double Cab 4x4 Off-Road Long Bed
    New and Unmodified
  6. Apr 25, 2012 at 8:51 AM
    AllBLKTaco
    AllBLKTaco Well-Known Member
    Denver
    07 TRD double cab
    Hey Guys and Gals, just a heads up! On my 2007 Tacoma after installing the seat covers my "airbag" light came on. I tried several different things to get it to go away including, disconnecting the battery for 30 minutes, rechecking all connections under both front seats to no avail. Finally bit the bullet and took it to the dealer. Turns out it came up with code #B1801 (Spiral Spring Faulty). Fortunately it was covered under the Airbag recall and was free of charge. If you guys see this, I'd suggest taking it into the dealer or just deal with the ANNOYING red light on your dash. Take Care.
  7. Apr 25, 2012 at 10:01 AM
    buzzard1992
    Alex
    Summerville, SC
    Well im a 1st gen so do you think it's the clock spring
  8. Jun 18, 2012 at 8:36 AM
    Tashier
    Tashier Well-Known Member
    Sean
    Beaverton, OR
    99 Tacoma V6 Limited
    Air Bar Suspension
    Ya that TSB looks like it was for second gens, not 1st.
