Air bag light on at random, no codes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Dec 31, 2019.
  1. Dec 31, 2019 at 9:04 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    2nd gen steering wheel comes out with nominal arm force, no puller needed. Slide hammers should be reserved for Mercedes Benz diesel injectors (look up videos on Youtube :laugh: )
    Anyway, spiral cable problems should result in codes stored even if the condition is intermittent.
    12TRDTacoma[OP] likes this.
  2. Dec 31, 2019 at 9:41 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    No, just a drinking problem and poor choices.
    It was a 2,ND gen Tundra.
  3. Dec 31, 2019 at 10:30 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I'm going to have to pull the code the moment the airbag light triggers then because there is literally nothing stored in there. The only scanner I didn't attempt to use was the Autel one I have which is the most feature rich one we have available.
    The 2nd gen steering wheel does not require a puller? You are meaning to tell me that I am able to perform the spiral cable swap at home without having to borrow one of those annoying puller tools from my work?
  4. Dec 31, 2019 at 10:31 PM
    Bishop84
    Bishop84 Well-Known Member
    I never use a puller on Toyotas.
    Remove the nut, bang the fat parts of the wheel with palm.
    Boom.
  5. Dec 31, 2019 at 10:32 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The warning light has always worked as it normally does. If there is a passenger on it, it indicates the airbag is on and if there is obscure weight being put on it it reads off. If the passenger is sitting in it without a seatbelt it indicates the icon as off, if they aren't wearing it, it will show the icon illuminated. It is not manually diaengagable like earlier gen 2nd gen.
  6. Dec 31, 2019 at 10:45 PM
    PyritePirateBill
    PyritePirateBill Well-Known Member
    Bill
    North Myrtle Beach, SC
    2014 pyrite mica TRD Sport 4x4 AC
    OME 886 Nitrocharger lift, Dakar HD leaf pack, u-bolt flip kit, Bilstein b110 rear shocks, Wheeler's super bumps,18x9 Worx Havoc, 35/12.50/18 Nitto Ridge Grapplers, ENVE Grille with LED lightbar & raptor leds, ditch lights, 6k hid, tinted tails, AtTheHelm bed stiffeners, SOS Concepts rear bumper, Demello baja front bumper, Smittybuilt 9.5k winch, Mobtown weld-on sliders, AllPro IFS & transm. skid, Mobtown transfer case skid, led fogs, led lights in rear bumper, 54" Bulldog hi-lift jack, Razorback shovel & axe on Quickfist mounts, Cobra CB w/Firestik antenna, Yellow wire mod for 4Lo, URD y-pipe, 2.5" custom exhaust w/ Borla muffler, Viair portable air compressor, Kryptek Typhon seat covers, AJT dash knobs
    Better yet, DON'T remove the nut all the way. Leave it on a few threads. Then when you pull on the wheel and it comes loose, the nut will still stop it from hitting you in the face.
    koditten and 12TRDTacoma[OP] like this.
  7. Jan 1, 2020 at 7:53 AM
    Bishop84
    You hit towards the steering wheel, you don't pull it off.
    It loosens, and a child can pull it off. I should take a video one day.
  8. Jan 1, 2020 at 9:47 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  9. Jan 1, 2020 at 9:54 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    The code should be stored even if the fault condition has gone away. Don't over-think it. Check those conditions listed in the service manual pages I attached if you haven't already.
    In case you do want to check the spiral cable anyway, 2nd gen steering wheel comes off with some wobbling, similar to this Prius (go to 09:10):
  10. Jan 1, 2020 at 10:03 AM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    If you have already had horn issues with the cable, then i would put a very good bet on that that is your issue. If its already giving you problems why wait anyways to see if it fails when you might actually want your airbag to deploy.
    Jimmyh likes this.
  11. Jan 4, 2020 at 10:47 AM
    Busbiz
    Busbiz Member
    07 std cab,std bed
    That clock spring was replaced under warranty/recall on my 2007 Tacoma at probably 200,000+ miles...O.C. Was air bag light on....​
  12. Jan 8, 2020 at 6:43 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Just to give an update to this I believe my airbag light was a very false code. I noticed the issue only occurs after making flash changes to my PCM via HPTuners and will go away and will stay off after having done the flash. I think as previously mentioned the SRS module is seeing lack of voltage during the flash and it doesn't like it which explains why the light trips on after starting the vehicle initially and driving it, then turns off and stays off anytime after the fact.
    Thanks for the insight guys! :thumbsup:
    koditten likes this.
  13. Jan 11, 2020 at 11:31 PM
    nguyas
    nguyas Active Member
    California
    2005 TRD tacoma
    I actually read an article about that recall...
    Spiral cable replacement on some trucks due to affecting airbag. It should be around here.
