Air bag light reset 2019 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Apes, Sep 28, 2020.
  1. Sep 28, 2020 at 12:39 PM
    Apes
    Apes [OP] New Member
    2019 White Tacoma TRD
    So I removed my seats in my 2019 PUSH START Tacoma but I didn’t disconnect the battery stupid me I know...
    The airbags didn’t deploy nothing bad happened but of course when I put the seats back in the airbag light is on and I don’t know how to reset it because it’s keyless. I appreciate any help with that.
    second thing anyone know of any problems I might have after I reset the light like will the airbags deploy if there is an accident?
  2. Sep 28, 2020 at 12:55 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    (a) Turn the ignition switch off.
    (b) Disconnect the cable from the negative (-) battery terminal, and wait for at least 90 seconds.
    (c) Disconnect and reconnect the connector to the combination meter assembly.
    (d) Connect the cable to the negative (-) battery terminal, and wait for at least 2 seconds.
    (e) Turn the ignition switch to ON.
    You might be able to just disconnect the battery for 90 seconds and reconnect it.:notsure:
  3. Sep 28, 2020 at 12:57 PM
    Bishop84
    Bishop84 Well-Known Member
    Wont clear until the passenger seat calibration is complete.
    Typically any SRS code will self clear as the system does a self check every start.
