Air Bag Light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ricotaco, Dec 18, 2010.
  1. Dec 18, 2010 at 5:26 PM
    ricotaco
    ricotaco [OP] New Member
    06 Tacoma 4Dr SR5
    Need some help here . . . My air bag light came on, any suggestions ?:eek:
  2. Dec 18, 2010 at 5:59 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    whats the code?
  3. Dec 18, 2010 at 7:31 PM
    danstacoma
    danstacoma Well-Known Member
    Dan
    pa
    07 Tacoma
    3 inch lift, painted badges, k&n cold air, cherry bomb, tinted windows, yellow fogs, and more to come
    im putting money on the clock spring mine did the same thing
  4. Dec 19, 2010 at 12:02 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Your wire harness will need to be replaced... if it is same problem my '05 had... Air bag light came on... and the defective wire harness was replaced... about $300 because out of warantee... I learn later that hundreds of second gen. tacos had the SAME problem!
  5. Jan 13, 2011 at 4:43 PM
    1FSTLS1
    1FSTLS1 Well-Known Member
    does the airbag still work???
    For real is it just the light or is it actually not functioning. Not sure how to test this one?
  6. Oct 25, 2013 at 5:45 PM
    grandpapacker
    grandpapacker Member
    Bill
    Chesapeake,Va
    SR5 Club Cab extended bed 4X4 V6
    Added weston running bds.,added chrome Bull Bar,added In-Channel Ventvisors Added outdoor temperature reading device using sensor mounted in grill,installed Tri-Fold Tonneau cover on truck bed
    Its part of a recall on Tacoma model years 2005 to 2009.It states that your "spiral cable assembly"needs to be replaced and that your drivers side AIR BAG might not deploy.Call 1-800-331-4331 and have your trks VIN handy.
  7. Oct 26, 2013 at 2:56 AM
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Louisiana
    Old Toyota's, Power Wagon, and a Tacoma
    Traded the 2015 TRD Pro 6spd Supercharged on a PowerWagon and could not be happier. My 2011 Tacoma with the TX Baja package (Added by me) is still treating me great. My 1985 Toyota never skips a beat.
    good info, thanks and welcome to TW :)
  8. Jan 2, 2014 at 6:15 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Thanks for this guys.
    My air bag light came on a week ago on my 06 with 86k miles.
    I entered my vin in this website and sure enough I had a recall.
    Took it to the Toyota dealer today and got it fixed for free.
  9. Jan 2, 2014 at 6:53 PM
    Silence9
    Silence9 Solve et Coagula
    Alberta, Canada
    Is this on your dash or by your clock? My airbag light is on but the on isn't.
  10. Jan 3, 2014 at 12:45 PM
    DDD
    Derek
    Santa Clarita, CA
    The light by the clock is ok.
    If the light by the tachometer on the dash stays on while driving then you have a problem.
