Air Bag Light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MARSHBUSTER, Nov 19, 2011.
  1. Nov 19, 2011 at 7:59 PM
    MARSHBUSTER
    MARSHBUSTER [OP] Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 8000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    While I was driving my truck today the Red Air Bag Light lit up and stayed on. ANY IDEAS???
  2. Nov 19, 2011 at 8:01 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Rob
    Pacific Northwest
    2018 TRD OR DCSB
    I read about this on here. Search "Clockspring"... That may be your issue. Hopefully it isn't a big problem. Good luck!
  3. Nov 19, 2011 at 8:02 PM
    Joe D
    Joe D .
    You got it turned on? Not sure if those are swithable? Have you lost the battery or otherwise removed power? Did you have something in the passenger seat that was light?
    Quick look on google also says to look for the cannon plug attached to the seat belt anchors...make sure it's attached and tight.
  4. Nov 21, 2011 at 4:20 PM
    MARSHBUSTER
    Jim
    Alamogordo NM
    Thanks for the replies, Its goes to the dealer on friday to get hooked up to there computer to see what the issue is.
  5. Nov 21, 2011 at 4:28 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    This is what made mine light up, after I installed the amp under the drivers seat. First time I moved the seat all the way back the plug got unplugged. Hope yours is an easy fix.
