AIR BAG light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by grandpapacker, Oct 25, 2013.
  1. Oct 25, 2013 at 5:27 PM
    grandpapacker
    grandpapacker [OP] Member
    Bill
    Chesapeake,Va
    SR5 Club Cab extended bed 4X4 V6
    Added weston running bds.,added chrome Bull Bar,added In-Channel Ventvisors Added outdoor temperature reading device using sensor mounted in grill,installed Tri-Fold Tonneau cover on truck bed
    The AIR BAG OFF ON and the AIR BAG light comes on when you turn the key to on.After starting the truck(2011 extended cab 4X4)the OFF ON lights goes out;but the AIR BAG light remains illuminated.I think this is part of a recall that I saw;but the recall says its for years 2005-2009.This recall states that the driver's side air bag might not deploy.I called Toyota customer service(1-800-331-4331)and gave her my VIN # and she said my 2011 truck was not included in that recall.She did suggest that I call my local dealership and talk to them.I called my dealership;but the service dept was not open.Its Fri.,10-25-13 @ 19:10.I'll call Sat. morning sometime after 0800 and ask them.Has anyone else ever had this sort of a problem.At first I was thinking that AIR BAG light staying on might be normal.Now I do not think it normally should stay illuminated.I'll report bk after I talk to my local service dept tomorrow morning.
  2. Oct 26, 2013 at 5:40 AM
    grandpapacker
    Bill
    Chesapeake,Va
    I called my local dealership and I'll take the truck in on Mon.10-28-13.Truck is still under warranty(14,750 miles,3 years old Aug.2014).I'll show you guys the results later next week.I also filed a complaint with the NHTSA.
    On Mon,10-28-13 my Toyota dealership replaced the spiral cable assembly that is connected to the airbag's control module and corrected my dash's airbag warning light.There was no charge because the truck is still under warranty(only 14,800 miles,2 yrs. 2 months old).Now my dash's airbag warning light does not stay on after the usual start-up illumination. I told NHTSA of the fix to my problem by Toyota.
    0.
  3. Oct 26, 2013 at 5:51 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Really? Without even knowing what is wrong you filed a NHTSA complaint? Isn't that a LITTLE premature?
  4. Oct 26, 2013 at 5:58 AM
    grandpapacker
    Bill
    Chesapeake,Va
    I don't think that its premature.I already know that its probally the "spiral cable assembly connected to the airbag's ctrl module" or possibly the "clockspring." I filed the complaint so other owners of 2011 Tacomas would be aware of this problem.When the air bag light stays on after starting there is a chance that the driver's side air bag won't deploy in event of a accident.
  5. Oct 26, 2013 at 6:02 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    You GUESS it might be that. I've got a truck with the "faulty part" - Still the original OEM sprial cable...No issues. So guessing that you have a problem w/ no proof and making a formal report - that is the definition of premature.
    Not to mention - it could be any number of things, but now some guy/gal at NHTSA has to investigate your claim, that you aren't even sure is correct, while plenty of legitimate claims stack up.
  6. Oct 26, 2013 at 6:13 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    you can pull your airbag codes with a paperclip.....fyi
  7. Nov 7, 2013 at 4:37 PM
    ronman737
    ronman737 Dangerous
    Ron
    Greenville, SC
    2008 4Runner 4x4 Sport
    Plz share.
  8. Nov 7, 2013 at 4:42 PM
    BamaToy1997
    Bill
    Navarre, FL
    not on the 2011 models. Not a good idea anyway to be using a paperclip to do anything on a vehicle.
  9. Nov 7, 2013 at 5:11 PM
    ronman737
    ronman737 Dangerous
    Ron
    Greenville, SC
    I have an 03 with my airbag light on. It doesnt blink. Just stays on.
  10. Nov 7, 2013 at 5:15 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    I had the spiral cable recall done on my 08 and the light only stays illuminated for about the first 3-5sec uppon start up. But it has never stayed illuminated....not even before the recall.
  11. Nov 7, 2013 at 6:16 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    not sure about 2011, i have an 09 and it worked perfect
    Its in the fsm
    And works just fine
  12. Nov 7, 2013 at 8:03 PM
    BamaToy1997
    Bill
    Navarre, FL
    Strange that any manufacturer would suggest just using a paper clip. I have seen so many diagnostic terminals I had to repair because a paper clip was jammed in and spread out the terminals. Would you have a link to the FSM? I'd really like to read what Toyota is suggesting.
  13. Nov 8, 2013 at 4:13 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    I DON'T KNOW HOW TO POST A PDF FROM MY PHONE BUT HERE IS A SCREEN SHOT
    THIS WORKS FOR YAW RATE CALIBRATION AND ABS FUNCTIONS AS WELL
    I HAVE DONE THE SRS DIAGNOSTIC'S ON EVERY SENSOR,SQUIB,MODULE, ON MY TRUCK AFTER SANDY TOOK HER UNDER
    IT WORKS AND IT WORKS WELL
    I HAD A GUY WITH A $$$$$ TESTER AND HE COULD NOT PULL THE CODES...HIS SPECIAL TESTER COULD NOT COMMUNICATE WITH MY MODULE BUT MY JUMPER WIRE "YES I DID NOT USE A PAPERCLIP BUT U CAN"
    AND THAT PULLED ALL 5 CODES I WAS THROWING
    IF YOU HAVE THE FSM YOU CAN LOOK IT UP UNDER AIR BAG SYSTEMS...."SRS"
    TORRA FSM IS DOWN:mad:
    I DO NOT KNOW IF THIS WORKS ON AN 2003 OR AN 2011
    BUT IT DID FOR MINE.....I USED THE PDF FROM THE FSM WHICH WAS FOR 05 AND UP
    UNSURE IF ANYTHING CHANGED BUT MY TRUCK HAS ALL THE ELECTRONIC CRAPOLA AND IT WAS GREAT......
  14. Nov 8, 2013 at 10:01 AM
    BamaToy1997
    Bill
    Navarre, FL
    That answers a lot there. So the FSM does NOT say use a paperclip, it states to use a specific jumper wire. THAT is what I was trying to get at. Using a paperclip can, and usually does end up damaging the terminal. Then when you try to connect up a scan tool or ultra gauge, you get no data, or intermittent data due to a damaged terminal. Not saying it happens every time, but I have seen the damage many, many times.
  15. Nov 9, 2013 at 1:16 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    Dude you are way over thinking things yes a paperclip a piece if wire what ever ....its not rocket science
    Hell go use your $2000 intelligent tester
    What ever works for you all your doing is making a temporary contact
    Have a good night
  16. Nov 9, 2013 at 2:19 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Bad seat belt switches will cause the air bag light to illuminate.
  17. Nov 10, 2013 at 5:41 PM
    BamaToy1997
    Bill
    Navarre, FL
    Calm down man. I was simply checking on information. I get additional info to help others by reading what some people post. I was curious because it sounded like the FSM was saying to actually use an actual paper clip to test. This is always a bad idea, and can damage the terminals. I never recommend people do something that can damage ANYTHING in their vehicle.
  18. Nov 10, 2013 at 6:03 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    BTW, OP, if you are referring to the "AIRBAG ON/OFF" on the center console, what you describe is normal.
    AIRBAG ON = Adult sitting in the passenger seat (or object heavy enough to activate the weight sensor)
    AIRBAG OFF = Seatbelt fastened, not enough weight to activate the weight sensor.
    AIRBAG = Seat is vacant, seatbelt not fastened.
  19. Nov 10, 2013 at 6:05 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    The spiral cable issue is in regard to the airbag graphic icon that appears in the tach display.
    THAT light should come on for a few seconds while the truck boots up, then go dark.
    With lights, brake, and cruise control off, no icons should be illuminated on the cluster.
  20. Nov 11, 2013 at 2:35 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    Whatever
    And your welcome
